dco application is not communicating to the Domain controller server
Select a Country
  • dco application is not communicating to the Domain controller server
Cory_McDonald Champion
159
Jef Leader
114
gsterling Mentor
77
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 03:16 PM . Last Modified: ‎2024-04-03 11:29 PM
1611
We are facing some issue with remote access ( application is not communicating to the active directory ) after DCO software up gradation from 8.1.0 to  8.2.12  , so we cannot log in to the application with our user accounts . we have logged through the local user and tried to configure authentication server set up as per the below links
http://sxwhelpcenter.ecostruxureit.com/display/UADCO8x/Configuring+authentication+servers+used+for+m...
 http://sxwhelpcenter.ecostruxureit.com/display/UADCO8x/Setup+an+AD+%28Active+Directory%29+Server
but the application is not communicating to the Domain controller server it is showing the error “serverValidationErrorLoginSetup”.
kindly help
(CID:137110833)
  • Data Center Operation
Replies 9
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 03:17 PM . Last Modified: ‎2024-04-03 11:29 PM
Hi shihabudheen,
Do I understand correctly that the remote authentication was working for you in 8.1?
If you were using the encryption (port 636) for the integration, probably (only guessing) there might be certificate change(s) on your AD server, then you could try to edit the Authentication server settings, re-enter the credentials and push Ok (to update the trust between the DCO and AD servers).
If you could provide the following data, then I will see what I can find:
1- screen captures of the configuration/settings, similar to image 1 and 2 from this guide: Setup an AD (Active Directory) Server
2- Screen capture illustrating where/how you see the error message
3- DCO server logs
4- client application.log file (usually located in C:\Users\\.isxo\8.2.12*\Operations\application.log)
5- copy of the latest backup file
I will send you an invite to my =S= box shortly, so the data safely can be provided/uploaded, thanks.
Kind regards
(CID:137110891)
DCIM_Support Mentor
Mentor
1611
Hi Shihabudheen,
I have received your data yet, but it is most likely language related,
the Authentication server settings feature in web-client is not localized, so most likely you might be running with non-English language.
In web client, go to your profile > Language, and change it to English:
And then begin your authentication server settings.
Kind regards
(CID:137111873)
DCIM_Support Mentor
Mentor
we had selected language English
(CID:137112305)
DCIM_Support Mentor
Mentor
(CID:137112307)
DCIM_Support Mentor
Mentor
According to your screen capture (from authentication server settings), client language was/is non - English - it is being translated incorrectly.
Kind regards
(CID:137725682)
DCIM_Support Mentor
Mentor
remote authentication was worked properly in 8.1
yes we are using the port 636 and there is no certificate issue in AD ( no changes in AD certificates , kindly note that we have used the same AD in 8.1
we are getting frequent error message when we are opening thin client through local user
screen
(CID:137112290)
DCIM_Support Mentor
Mentor
  1.
    This issue has been resolved by setting up server authentication through the DCE , we can access the DCO application with our user accounts now
(CID:137112603)
DCIM_Support Mentor
Mentor
Hi Shihabudheen,
Apparently the ssl communication may need to be updated. It seems your client is set to non English language - to be able to use the authentication server settings you would need to switch the client language to English.
Kind regards
(CID:137725680)
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 03:17 PM . Last Modified: ‎2023-10-22 04:30 AM
