Continue
  • My Subscriptions
  • Events
can't log on DCE via client
  • can't log on DCE via client
Cory_McDonald Champion
160
Jef Leader
114
gsterling Mentor
79
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-03 09:50 AM . Last Modified: ‎2024-04-08 03:12 AM
1274
When log on the DCE client ,input username and password ,it showing "can't find  the ip ****( the ip address of  DCE)".
How can we  access to the DCE server? Pls help!
(CID:110014380)
Replies 4
DCIM_Support Mentor
Mentor
Hi, zzkzzk,
The first thing to do is to use that same computer and access that ip using a web browser. The client uses the same protocol as the web, either http or https. If the browser can not get to the ip, either the server is down, the network has issues, or you have the wrong ip.
If if you can access via web, make sure you use the same protocol, http or https.  If you can't get to it with that protocol (using browser but not client) and assuming the page has no errors, you may want to look at antivirus or firewall.  These can not only be configured to block ip or port but can block software as well
Steve
(CID:110014384)
DCIM_Support Mentor
Mentor
Hi Steve,
    Thank!
     Network, IP and firewall have  correct settings .And another computer can access   the DCE  server.
     I've heard some person say that a similar problem has been discovered and that the solution is to replace a file in the installation file with a new one, but I do not know the details. Do you have similar experience?
    thanks again!
(CID:110015325)
DCIM_Support Mentor
Mentor
Hi Hi, zzkzzk,
I'm not sure exactly to what file they're referring however you may simply want to uninstall and reinstall. If that fails, Go to C:\Users\(your user name)\ folder and rename the ".isxc" folder. This has all the IPs and user names you may have saved for all the different versions and systems you've accessed. It should be recreated when you access StruxureWare again. I suggest renaming it as if this doesn't resolve the issue, you can put that data back.
Steve
(CID:110015333)
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-03 09:50 AM . Last Modified: ‎2023-10-22 04:26 AM
