What is the tool to fetch data with DCE API
EcoStruxure IT Forum
  • Re: What is the tool to fetch data with DCE API
Cory_McDonald
Cory_McDonald Champion
159
Jef
Jef Leader
114
gsterling
gsterling Mentor
77
Back to EcoStruxure IT Forum
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 11:56 PM . Last Modified: ‎2024-04-02 11:45 PM
1139
Hi Community,
Can anyone help me to fetch data from Data Center Expert through API's using what tools? and procedure.
Any guild will be highly appreciated.
(CID:152080615)
  • Data Center Expert
Replies 3
DCIM_Support
DCIM_Support Mentor
Mentor
Hello Shaik
SOAP is probably the most common tool used to manually query a DCE server using its API's.
Assuming you can view the page I pasted below, the bottom section of this page describes how to make a general call from SOAP to DCE when verifying sensor data.
https://sxwhelpcenter.ecostruxureit.com/display/DCIMDEVELOPER/DCE+Sensor+Mapping+to+DCO
Greg Sterling
(CID:152080629)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 11:57 PM . Last Modified: ‎2024-04-02 11:45 PM
Hi Shaik,
All the documentation that's available is located here:
https://sxwhelpcenter.ecostruxureit.com/display/UADCE725/User+assistance+for+StruxureWare+Data+Cente...
Look under the links marked:
Web services API
Alarms service methods
Device group service methods
Device service methods
Sensor service methods
There are tutorials on-line, I've found one here:
https://www.guru99.com/soapui-tutorial.html
SoapUI is one of the tools you can use to work with this API
https://en.wikipedia.org/wiki/SoapUI
(CID:152080639)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 11:57 PM . Last Modified: ‎2023-10-22 04:18 AM
