UI-16 I/O module wiring various signal standards
Select a Country
  • UI-16 I/O module wiring various signal standards
Cory_McDonald Champion
159
Jef Leader
114
gsterling Mentor
77
Posted: ‎2021-01-17 11:30 PM . Last Modified: ‎2021-01-17 11:51 PM
2051
I want connect various signal standards to one UI-16 I/O module, for example:
- 4...20 mA (from 2-wire transmitter, with external power source for supply current loop)
- 4...20 mA (from 4-wire transmitter, with active analog output)
- 0...10 V (feedback from actuator, actuator has an independet power supply)
Can I wire, for example, 4...20 mA signal to terminal no 1 and 0...10 V to terminal no 3 (despite the common RET terminal) ?
Can I wire, for another example, 4...20 mA (from 2-wire transmitter, with external power source for supply current loop) to terminal no 1 and 4...20 mA (from 4-wire transmitter, with active analog output) to terminal no 3?
And another question: the manufacter suggests, that system configuration requires a PELV circuit.
https://ecostruxure-building-help.se.com/bms/Topics/show.castle?id=11940&locale=pl-PL&productversion...
Is it necessary in my case?
Can I wire temperature sensor STP 100-250 direct to UI-16?
Are there any special wiring requirements?
  • Product Feedback
  • Tips and ideas
Posted: ‎2021-01-20 01:56 AM
you can create your own creativity. These tough economic times force us to innovate.
Posted: ‎2021-01-21 11:31 PM
I guess that you can connect various signals in any configuration to this module within this range:
