UI-16 I/O module wiring various signal standards
EcoStruxure IT Forum
Exact phrase→Use quotes " "(e.g., "error 404")
Wildcard→Use * for partial words(e.g., build*, *tion)
AND / OR→Combine keywords(e.g., login AND error, login OR sign‑in)
Keep it short→Use 2–3 relevant words, not full sentences
Filters→Narrow results by section(Knowledge Base, Users, Products)
Send InviteCancel
Posted: 2021-01-1711:30 PM. Last Modified: 2021-01-1711:51 PM
I want connect various signal standards to one UI-16 I/O module, for example:
- 4...20 mA (from 2-wire transmitter, with external power source for supply current loop)
- 4...20 mA (from 4-wire transmitter, with active analog output)
- 0...10 V (feedback from actuator, actuator has an independet power supply)
Can I wire, for example, 4...20 mA signal to terminal no 1 and 0...10 V to terminal no 3 (despite the common RET terminal) ?
Can I wire, for another example, 4...20 mA (from 2-wire transmitter, with external power source for supply current loop) to terminal no 1 and 4...20 mA (from 4-wire transmitter, with active analog output) to terminal no 3?
And another question: the manufacter suggests, that system configuration requires a PELV circuit.
