Continue
  • My Subscriptions
  • Events
SNMP device configuration template
EcoStruxure IT Forum
  • Re: SNMP device configuration template
Cory_McDonald
Cory_McDonald Champion
160
Jef
Jef Leader
114
gsterling
gsterling Mentor
79
Back to EcoStruxure IT Forum
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 07:46 PM . Last Modified: ‎2024-04-04 11:07 PM
914
Do I need create a separate snmp device configuration template for every type of device or can I make use of the same template for all device ?
For example, I need to enable snmp v3 for all device, I notice that some device has more fields than other device (eg most rack PDU have Authentication Protocol & Encryption Protocol field while NB Rack Access PX HID doesn't). So Can I use the template with all fields even on those NB Rack Access PX HID without those fields ?
(CID:132660054)
  • Data Center Expert
Replies 2
DCIM_Support
DCIM_Support Mentor
Mentor
Hi Francis,
Your first question:
It is more of a matter of preference / standardization you want to do.
I usually try to minimize the number of templates using common template for applicable devices, and only create another template for specific group of devices that has different config.
I do not have the answer for your specific second question on applying SNMPv3 template with auth & encryption for Rack Access HID.
You may want to split it to 2 config template:
1.SNMP V3 template with auth & encryption, for majority of  your devices.
2.Another template for SNMPv3 without auth & encryption for the remaining.
(CID:132660080)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 07:46 PM . Last Modified: ‎2023-10-22 03:49 AM
