Continue
  • My Subscriptions
  • Events
Regional settings for Celcius
EcoStruxure IT Forum
Showing results forΒ
Did you mean:Β
  • πŸ”’ Closed
Cory_McDonald
Cory_McDonald Champion
160
Jef
Jef Leader
114
gsterling
gsterling Mentor
79
Back to EcoStruxure IT Forum
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: β€Ž2020-07-05 05:06 PM . Last Modified: β€Ž2024-04-03 04:15 AM
1726
Datacenter Expert 7.6.0 client does not recognize Sweden as a regional setting with Celcius as the standard value for temperature. I have tried to change my Windows 10 to English (UK) and it works, but with Swedish I only get Farenheit.
(CID:140216572)
  • Data Center Expert
DCIM_Support
DCIM_Support Mentor
Mentor
Regional settings on the server do not change settings on the client application. By default, the client is set to use the OS locale. Go to file and client preferences:
But here you can see that after changing to English Metric:
Now you can see that those same sensors are in Celsius:
If you're looking at the web, Click the settings menu and choose the correct temperature scale there for web viewing:
(CID:140216698)
Replies 6
DCIM_Support
DCIM_Support Mentor
Mentor
(CID:140216698)
DCIM_Support
DCIM_Support Mentor
Mentor
1726
Thank you Steve!
I tried this and it doesnt work for swedish in Windows10:
Per
(CID:140218418)
DCIM_Support
DCIM_Support Mentor
Mentor
In response to DCIM_Support
Hi Per,
OS Locale may not work and I can make note of that for the engineering team but have you tried other settings as I had shown here?:
(CID:140218481)
DCIM_Support
DCIM_Support Mentor
Mentor
Aha! That solved IT! Thanks!
//Per
(CID:140218574)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: β€Ž2020-07-05 05:07 PM . Last Modified: β€Ž2024-04-03 04:15 AM
Daniel Kwong FYI
(CID:140218749)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: β€Ž2020-07-05 05:07 PM . Last Modified: β€Ž2023-10-22 03:45 AM
Terms & Conditions Privacy Notice Change your Cookie Settings Β© 2026 Schneider Electric
