Posted: 2020-07-05 05:06 PM . Last Modified: 2024-04-03 04:15 AM
Datacenter Expert 7.6.0 client does not recognize Sweden as a regional setting with Celcius as the standard value for temperature. I have tried to change my Windows 10 to English (UK) and it works, but with Swedish I only get Farenheit.
(CID:140216572)
Regional settings on the server do not change settings on the client application. By default, the client is set to use the OS locale. Go to file and client preferences:
But here you can see that after changing to English Metric:
Now you can see that those same sensors are in Celsius:
If you're looking at the web, Click the settings menu and choose the correct temperature scale there for web viewing:
(CID:140216698)
(CID:140216698)
Thank you Steve!
I tried this and it doesnt work for swedish in Windows10:
Per
(CID:140218418)
Hi Per,
OS Locale may not work and I can make note of that for the engineering team but have you tried other settings as I had shown here?:
(CID:140218481)
Aha! That solved IT! Thanks!
//Per
(CID:140218574)
Posted: 2020-07-05 05:07 PM . Last Modified: 2024-04-03 04:15 AM
Daniel Kwong FYI
(CID:140218749)
Posted: 2020-07-05 05:07 PM . Last Modified: 2023-10-22 03:45 AM
