Network flow documentation - UPS to Gateway
Select a Country
  • Network flow documentation - UPS to Gateway
Cory_McDonald Champion
160
Jef Leader
114
gsterling Mentor
77
EcoStruxure™ IT Expert
IT Expert
Dave.Batten
Dave.Batten
Explorer
Posted: ‎2026-09-14 07:07 AM
133
Is there any documentation on the network traffic flow between a UPS and the IT Gateway using SNMPv3?
We recently moved our on-prem gateway to an Azure instance, and then changed our WAN network. SNMP isn't routing correctly, and my networking team would like some technical documentation detailing the answer/response, the ports that need to be opened, etc.
  • IT Expert
Champion
Posted: ‎2026-09-17 11:51 AM
Hello @Dave.Batten,
The ports that the gateway uses to communicate can be found here: https://community.se.com/t5/System-requirements/Gateway-default-ports/ta-p/447007
The specific questions around ports used for Communication to the UPS can be found within the Device communication section.  The default device ports in question for SNMPv3 would usually be port 161 outbound from the gateway.  If a non-default port is being used, you would need to verify that within the device and the gateway and then unblock the specific port being used.
Kind Regards,
Cory
