Netbotz Rack Monitor 250
EcoStruxure IT Forum
  • Netbotz Rack Monitor 250
Cory_McDonald
Cory_McDonald Champion
159
Jef
Jef Leader
114
gsterling
gsterling Mentor
77
Back to EcoStruxure IT Forum
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 09:51 PM . Last Modified: ‎2024-04-04 03:31 AM
1153
i am facing problem in my Netbotz Rack monitor 250 packet drop on network.
when i directly attach laptop to netbotz same packet drop and no proper communication with sensors.
please advice me how to resolve this issue.
i am using cross over cable and straight also but packet drop.
(CID:133372775)
  • NetBotz
Replies 3
DCIM_Support
DCIM_Support Mentor
Mentor
Hi Abdul,
Good day!
To properly identify the problem that you are reporting, it is best to start with identifying the behavior of the status (marked with a check and x symbol) and link (marked 10/100) LEDs on the network port. The behaviour of the LEDs should confirm whether or not the Netbotz 250 is working or not.
Another thing that you need to consider is whether or not a static IP address was assigned to the Netbotz 250 prior to the crossover connection attempt (I am assuming that you confirmed the dropped packets by pinging the IP address of the Netbotz appliance as this is the easiest way of doing it).
It is also a good idea to check and review how the direct/crossover cable connection was done. Feel free to use the link below for your reference:
http://www.apc.com/us/en/faqs/FA156366/
Unfortunately, it is too early to tell what is causing the Netbotz 250 to not.communicate. We might need to get additional information from you before we can provide a recommendation.
I hope this helps.
Justine Chester
(CID:133372834)
DCIM_Support
DCIM_Support Mentor
Mentor
Dear Abdul Qadir Bhatti,
Tell us, please, have you solved this problem or not?
With respect.
(CID:134026501)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 09:51 PM . Last Modified: ‎2023-10-22 03:23 AM
