Netbotz 750 error in voltage
Select a Country
  • Netbotz 750 error in voltage
Cory_McDonald Champion
159
Jef Leader
114
gsterling Mentor
77
ColeRFF
ColeRFF
Explorer
Posted: ‎2026-03-12 10:54 AM
278
U-Boot 2018.04 (Aug 30 2019 - 14:54:28 -0400)
CPU: Altera SoCFPGA Platform
FPGA: Altera Cyclone V, SE/A6 or SX/C6 or ST/D6, version 0x0
BOOT: QSPI Flash (3.0V)
Watchdog enabled
I2C: ready
DRAM: 2 GiB
MMC: dwmmc0@ff704000: 0
Loading Environment from SPI Flash... SF: Detected s25fl512s_256k with page size 512 Bytes, erase size 256 KiB, total 64 MiB
OK
In: serial
Out: serial
Err: serial
Model: ECP SNARC SOCA9 2G for Bestla board
Net: No ethernet found.
Hit any key to stop autoboot: 0
Card did not respond to voltage select!
ERROR : the map table is corrupted.........0x0
mapTable : crc=00000000
ERROR MAGIC NUMBER: probably because there is no map table.
ecpmt_banks_load - Set enviroment variable for ECP_FWU banks
Usage:
ecpmt_banks_load
## Error: "check_rtc" not defined
** Bad device mmc 0 **
device 0 offset 0x140000, size 0x800000
SF: 8388608 bytes @ 0x140000 Read: OK
Detected SoCA9 Snarc board revision=4
FPGA updated to correct revision.
Minimum FPGA Release: 7
FPGA Git Commit ID: 0x6a72ce7c, Build unix timestamp: 1525264765
Champion
Posted: ‎2026-03-17 01:28 PM
Hello @ColeRFF,
This seems to be an issue related to something around the storage.  I recommend reaching out to support to troubleshoot the appliance further and look into any available options.
Kind Regards,
Cory
