Netbotz 320/420 firmware location
EcoStruxure IT Forum
  • Exact phrase โ†’ Use quotes " " (e.g., "error 404")
  • Wildcard โ†’ Use * for partial words (e.g., build*, *tion)
  • AND / OR โ†’ Combine keywords (e.g., login AND error, login OR signโ€‘in)
  • Keep it short โ†’ Use 2โ€“3 relevant words , not full sentences
  • Filters โ†’ Narrow results by section (Knowledge Base, Users, Products)
Showing results forย
Did you mean:ย
  • Re: Netbotz 320/420 firmware location
Cory_McDonald
Cory_McDonald Champion
160
Jef
Jef Leader
114
gsterling
gsterling Mentor
77
Back to EcoStruxure IT Forum
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: โ€Ž2020-07-05 04:25 PM . Last Modified: โ€Ž2024-04-03 05:06 AM
2552
Does anyone know where I can find the firmware for 320/420 Netbotz appliance.
On the old APC forum the link I think I need is no longer accessible.
http://updates.netbotz.com/patches/bw/2.6.2/tftpCobra262.zip
(CID:138808184)
  • NetBotz
Replies 9
DCIM_Support
DCIM_Support Mentor
Mentor
2550
Hi Tim,
If you just need Advanced View, it's available here:
http://updates.netbotz.com/releases_500/2.6/install.htm
The site no longer has the raptor firmware but I have a box link you can use:
https://schneider-electric.box.com/s/gwc66epysuzij1j6uk0w91357qcjmany
(CID:138808219)
DCIM_Support
DCIM_Support Mentor
Mentor
In response to DCIM_Support
Thanks Steve. I think I need Cobra firmware. When my 320e boots it says Board Cobra.
I've set up TFTP server and when I run postupg from terminal session it seems to be looking for cobraboot.bin which I don't have in my TFTP directory.
We have three of these bricked like this from when we did a factory reset. They all boot up with "verifying Checksum.. Bad CRC". If we can save my boss from having to buy new we would make him happy.
(CID:138809225)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: โ€Ž2020-07-05 04:26 PM . Last Modified: โ€Ž2024-04-03 05:06 AM
Yea, I wondered about that but it's been a while and I forgot which was which so I took your word for it ๐Ÿ˜‰ :
https://schneider-electric.box.com/s/x4xmltggys1yxweribg3
(CID:138809223)
DCIM_Support
DCIM_Support Mentor
Mentor
Thanks for being so helpful. That firmware is now loading with postupg but when I do rootupg it fails booting with bad CRC (attached bad CRC.png) . It looks like the same problem as I have when I do a factory reset. I can see a similar post on Google on the old forums.apc.com. Unfortunately it is no longer there nor on Wayback.
(CID:138809292)
DCIM_Support
DCIM_Support Mentor
Mentor
Hi Tim,
I'm not able to test the firmware today, I will double check when I get some time. Normally I would look at firmware specifically for this issue but if you are having a similar issue with this same appliance on a simple configreset, it sounds like it's something more specific to the bot. If you have another 320 or 420, I'd ask that you test the firmware on it if you're able. That would at lease point the finger in the right direction. If it is hardware, sadly there's little we can do.
(CID:138809320)
DCIM_Support
DCIM_Support Mentor
Mentor
Thanks Steve. I appreciate your help. It is beyond the call of duty. It's doing the same on 2 other 320e. They are old so I would not be surprised if they are borked.
(CID:138809328)
DCIM_Support
DCIM_Support Mentor
Mentor
Firmware is fine. I was being a numpty and missed the middle kernupg flash. 320_420 tftp flash procedure.txt
All 3 devices are booting and I can see them through Advanced View. Thanks for your help Steve. Cobra firmware was missing part.
(CID:138809819)
DCIM_Support
DCIM_Support Mentor
Mentor
Glad you got it working! Would have been a shame to throw them all away.
(CID:138809859)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: โ€Ž2020-07-05 04:26 PM . Last Modified: โ€Ž2023-10-22 03:18 AM
Youโ€™ve reached the end of your document
WHATโ€™S NEXT?
Terms & Conditions Privacy Notice Change your Cookie Settings ยฉ 2026 Schneider Electric
