Continue
  • My Subscriptions
  • Events
NetBotz Rack Monitor 570>Rack Access Pod 170>lock control
EcoStruxure IT Forum
Showing results forΒ
Did you mean:Β
  • πŸ”’ Closed
Cory_McDonald
Cory_McDonald Champion
160
Jef
Jef Leader
114
gsterling
gsterling Mentor
77
Back to EcoStruxure IT Forum
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: β€Ž2020-07-04 06:05 PM . Last Modified: β€Ž2024-04-04 11:42 PM
1238
The Netbotz are monitored by DCE and are integrated to ecoStruxureware platform, we need a way to force a state change of the lock on the front and rear of the access pods?
I cannot find any wsdl or api in any documentation that suggest this is possible, I have looked through netbotz, DCE, DCO, SBO.
Thanks in advance.
Jared
(CID:131964813)
  • Data Center Expert
  • Data Center Operation
  • IT Advisor
  • NetBotz
  • Portal
DCIM_Support
DCIM_Support Mentor
Mentor
Hi Jared,
I don't imagine this could be supported, but can you please describe exactly what you want to achieve?
Kind regards
(CID:132658155)
Replies 2
DCIM_Support
DCIM_Support Mentor
Mentor
Hi Jared,
Kind regards
(CID:132658155)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: β€Ž2020-07-04 06:05 PM . Last Modified: β€Ž2023-10-22 03:14 AM
Terms & Conditions Privacy Notice Change your Cookie Settings Β© 2026 Schneider Electric
