NetBotz DDF for Uniflair
EcoStruxure IT Forum
  • Re: NetBotz DDF for Uniflair
Cory_McDonald
Cory_McDonald Champion
160
Jef
Jef Leader
114
gsterling
gsterling Mentor
77
Back to EcoStruxure IT Forum
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 04:12 AM . Last Modified: ‎2024-04-05 03:04 AM
1424
Hi
We recently implemented the DDF file for Uniflair Leonardo in DCE
It seems to work well 😀
It seems that the same DDF file is NOT working in NetBotz device scan
Question is - How to get the DDF for NetBotz, if we have created this?
Thanks in advance 😀
 BR
Mogens
(CID:128067672)
  • NetBotz
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 04:13 AM . Last Modified: ‎2024-04-05 03:04 AM
1423
Hi Mogens,
I do not believe that NetBotz DDFs are being created at this time. For that, I'll defer to the DDF team if they're aware of any effort in that area.
I do know that the DCE DDFs are too big for the NetBotz appliances and won't work. I suggest removing that DDF and if you must poll the device with a NetBotz appliance, perhaps using the supplemental OID feature will get you the info you need.
(CID:128067688)
Replies 5
DCIM_Support
DCIM_Support Mentor
Mentor
Hi Mogens,
As you probably already know, the DDFs for DCE and NetBotz are different. However, I don't think we are actively writing any new DDFs for NetBotz any more.
Someone else might want to elaborate on this also.
(CID:128067684)
DCIM_Support
DCIM_Support Mentor
Mentor
1424
Hi Mogens,
(CID:128067688)
DCIM_Support
DCIM_Support Mentor
Mentor
In response to DCIM_Support
OK, thank you John and Steve!
You confirm my expectation on NetBotz DDF, and probably it is rare that customers request this NetBotz SNMP scan feature for new devices.
BR Mogens
(CID:128747771)
DCIM_Support
DCIM_Support Mentor
Mentor
Device support team only develops DDFs for DCE and gateway (StruxureOn). I will share you post/question with my developer contact at Netbotz.
(CID:128747774)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 04:13 AM . Last Modified: ‎2023-10-22 03:13 AM
