NetBotz 750 with the 5-node monitoring license (NBWN0006)
Select a Country
  • NetBotz 750 with the 5-node monitoring license (NBWN0006)
Cory_McDonald Champion
159
Jef Leader
114
gsterling Mentor
77
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 07:20 PM . Last Modified: ‎2024-04-03 02:41 AM
1831
Hi
I looking to monitor other devices via SNMP from the new NetBotz appliance 750. Can use 5-node monitoring license.
Is there an updated compatibility chart, of sensors, netbotz and software licenses?
(CID:143758191)
  • DDF
  • NetBotz
DCIM_Support Mentor
Mentor
1830
Hi Miguel,
the 750 is not compatible with the 5 node monitoring pack license key. There is no firm date at this time but it is planned that in a future release of the 750's firmware, it will support some SNMP devices on it's private LAN similar to DCE. There is no firm number of supported devices yet and as I mentioned, there is no firm date as to when this option may be released.
Steve,
(CID:143758210)
Replies 5
DCIM_Support Mentor
Mentor
1831
Hi Miguel,
Steve,
(CID:143758210)
DCIM_Support Mentor
Mentor
Thanks Steven
There is a chart of compatibility between sensors, netbotz and software licenses?
(CID:143758219)
DCIM_Support Mentor
Mentor
Hi Miguel,
I thought you wanted the compatibility matrix to see if the license was compatible but yes, there is an updated version that includes the 750:
https://download.schneider-electric.com/files?p_enDocType=Specification+guide&p_File_Name=JHIN-7PTK7...
Steve.
(CID:143758221)
DCIM_Support Mentor
Mentor
Tanks
(CID:143758223)
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 07:20 PM . Last Modified: ‎2023-10-22 03:13 AM
