NetBotz 250 - PRTG Sensors reporting false values for Temp and Humidity since NetBotz Firmware update
EcoStruxure IT Forum
  • Re: NetBotz 250 - PRTG Sensors reporting false values for Temp and Humidity since NetBotz Firmware update
Cory_McDonald
Cory_McDonald Champion
159
Jef
Jef Leader
114
gsterling
gsterling Mentor
77
Back to EcoStruxure IT Forum
mr12
mr12
Explorer
Posted: ‎2023-01-16 05:20 AM
5
2722
Since upgrading the firmware on our NetBotz 250 devices the snmp PRTG Sensors are reporting -1% for Humidity and 0 for Temperature for all of our devices but Data Centre Expert is reporting the correct values.
Firmware Updated from App v6.8.0, AOS 6.8.2, Boot v1.0.8 to App v7.0.6, AOS v7.0.6, Boot v1.0.8 Network Management Card Model Number AP9538.
Sensors OID 1.3.6.1.4.1.318.1.1.10.3.13.1
Humidity 1.3.6.1.4.1.318.1.1.10.3.13.1.1.6
Temperature 1.3.6.1.4.1.318.1.1.10.3.13.1.1.3
Has anyone else had this issue or similar? All the NetBotz are affected and I am unable to find a copy of the previous firmware to roll back.
  • NetBotz
Replies 5
reej
reej
Explorer
Posted: ‎2023-01-16 05:35 AM
2703
What kind of sensors you have ?
Wireless Zigbee of RJ45 connection
mr12
mr12
Explorer
Posted: ‎2023-01-16 07:57 AM
In response to reej
2697
They are the Wired RJ45 Sensors
reej
reej
Explorer
Posted: ‎2023-01-16 08:18 AM . Last Modified: ‎2023-01-16 08:19 AM
In response to mr12
please try:
Sensors OID  .1.3.6.1.4.1.318.1.1.10.1.3.3.1
Humidity  1.3.6.1.4.1.318.1.1.10.1.3.3.1.6
Temperature 1.3.6.1.4.1.318.1.1.10.1.3.3.1.4
read from powernet441.mib
Shaun
Shaun Leader
Leader
Posted: ‎2023-01-16 09:56 AM . Last Modified: ‎2023-01-16 09:56 AM
2683
Hi @mr12,
The ..318.1.1.10 OIDs are legacy support for the old APC Environmental Monitors (old units from about the era when someone decided modern electronics shouldn't be beige!).  It appears this legacy support is drying up.
You should find what you're looking for under the .1.3.6.1.4.1.318.1.1.25.1 tree, which is intended for these UIO sensors.  Examples from one I have here:
.1.3.6.1.4.1.318.1.1.25.1.2.1.1.1.1 = INTEGER: 1 (uioSensorStatusPortID)
.1.3.6.1.4.1.318.1.1.25.1.2.1.2.1.1 = INTEGER: 1 (uioSensorStatusSensorID)
.1.3.6.1.4.1.318.1.1.25.1.2.1.3.1.1 = STRING: "Port 1 Temp 1" (uioSensorStatusSensorName)
.1.3.6.1.4.1.318.1.1.25.1.2.1.4.1.1 = STRING: "Port 1" (uioSensorStatusSensorLocation)
.1.3.6.1.4.1.318.1.1.25.1.2.1.5.1.1 = INTEGER: 68 (uioSensorStatusTemperatureDegF)
.1.3.6.1.4.1.318.1.1.25.1.2.1.6.1.1 = INTEGER: 20 (uioSensorStatusTemperatureDegC)
.1.3.6.1.4.1.318.1.1.25.1.2.1.7.1.1 = INTEGER: -1 (uioSensorStatusHumidity; this isn't a THM so -1 means not available)
.1.3.6.1.4.1.318.1.1.25.1.2.1.8.1.1 = INTEGER: 0 (uioSensorStatusViolationStatus)
.1.3.6.1.4.1.318.1.1.25.1.2.1.9.1.1 = INTEGER: 1 (uioSensorStatusAlarmStatus)
.1.3.6.1.4.1.318.1.1.25.1.2.1.10.1.1 = INTEGER: 2 (uioSensorStatusCommStatus, 2=OK)
And for each of these, replace the final .1.1 with .2.1 for the second built-in UIO port.
mr12
mr12
Explorer
Posted: ‎2023-01-17 11:08 AM
In response to Shaun
Do you use the NetBotz 250 devices?
