Posted: 2020-07-05 05:37 PM . Last Modified: 2024-04-03 03:18 AM
Hallo,
When i try to login DCO8.2.2 i get te next massage:
Login failed because of SSL issues.
What is the problem and how do i solve that?
(CID:140709769)
Hello Stefan.
Which interface is returning the SSL error? Is this the DCO web client, desktop client or both? Do you use your own SSL certificate or is your server using the default self-assigned ssl certificate?
Greg Sterling
(CID:140709957)
Hello Greg,
The issue is already solved luckely.
It was an active directory issue.
Thanks anyway.
Stefan Sturm
(CID:140711252)
Posted: 2020-07-05 05:38 PM . Last Modified: 2023-10-22 02:57 AM
