Posted: 2026-05-29 09:03 AM
I was just notified that there are 3 more vulnerabilities related to this original copy fail exploit. Can you please look into if there is or will be patching available for the following: CVE-2026-43284, CVE-2026-43500, and CVE-2026-31635. Thank you in advance.
Posted: 2026-06-02 01:54 AM
You might want to mention which system you are currently using so that the team can advise accordingly. To report or to check vulnerability in SE's products, you may refer to the Cybersecurity support portal as follows:
https://www.se.com/ww/en/work/support/cybersecurity/security-notifications/
BR,
TJ
Posted: 2026-06-03 01:41 PM
This would be for using EcoStruxure Data Center Expert Client Build 8.3.0.91 and Server Build 8.3.0.91.
