Is DCE v7.4.3 compatible with DCO v7.4.0
EcoStruxure IT Forum
  • Re: Is DCE v7.4.3 compatible with DCO v7.4.0
Cory_McDonald
Cory_McDonald Champion
159
Jef
Jef Leader
114
gsterling
gsterling Mentor
77
Back to EcoStruxure IT Forum
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 12:16 AM . Last Modified: ‎2024-04-05 04:38 AM
1112
Is the latest DCE v7.4.3 compatible with DCO 7.4.0? My client is only looking at upgrading his DCO server to version 8 later in the month but has recently upgraded DCE from v7.4.0 to v7.4.3. He has now picked up DCE is not communicating with DCO. He is able to ping from DCE  to DCO but when testing the external system he is getting an error that DCE could be down.
(CID:126161520)
  • Data Center Expert
  • Data Center Operation
DCIM_Support
DCIM_Support Mentor
Mentor
1112
Hi Kevin,
DCE 7.4.3 is not compatible with DCO 7.4. Your observation is correct that the previous/old versions of DCO (such as 7.4) cannot not be integrated properly with the latest versions of DCE (7.4.3). It sounds great that customer has already planned to upgrade the product to 8.x, which is highly recommended.
Kind regards
(CID:126161531)
Replies 4
DCIM_Support
DCIM_Support Mentor
Mentor
1113
Hi Kevin,
Kind regards
(CID:126161531)
DCIM_Support
DCIM_Support Mentor
Mentor
In response to DCIM_Support
Thank you Jef! Much appreciated!
(CID:126161556)
DCIM_Support
DCIM_Support Mentor
Mentor
You are most welcome, Kevin
Kind regards
(CID:126161560)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 12:16 AM . Last Modified: ‎2023-10-22 02:47 AM
