Install EcoStruxure IT Gateway on Windows - Install Fails
Select a Country
  • Install EcoStruxure IT Gateway on Windows - Install Fails
Cory_McDonald Champion
159
Jef Leader
114
gsterling Mentor
77
Mateusz_Teco
Mateusz_Teco
Explorer
Posted: ‎2026-07-06 06:58 AM . Last Modified: ‎2026-07-31 11:10 AM
2
529
We need an older or alternative EcoStruxure IT Gateway installer.
The current installer EcoStruxure IT Gateway 2.2.0.16 fails on Windows 10 and also on a clean Windows 10 virtual machine.
The installation fails during the post-install step:
"Failed to configure gateway application"
PostgreSQL files are copied and the data directory is initialized, but the installer does not start PostgreSQL correctly. When we manually run pg_ctl.exe from an elevated CMD, PostgreSQL starts and listens on port 5432, but the installer still rolls back and removes the files.
Could you please provide another Gateway version, for example 2.1.x or 1.23.1.10, or a fixed installer?
  • IT Expert
Chavamex55
Chavamex55
Explorer
Posted: ‎2026-07-30 06:47 PM
Also have the same problem as comment above and I see no answer to the issue.
Please support.
Champion
Posted: ‎2026-07-31 11:20 AM
@Mateusz_Teco & @Chavamex55,
Please reach out to technical support to investigate this issue as log files will likely need to be analyzed.  We do not ask for log files within the community for security reasons (IP Addresses, etc) that may be contained within the log files.
How to gather log files for a gateway installation: https://community.se.com/t5/Troubleshooting/Gathering-Gateway-logs-for-troubleshooting/ta-p/447142
Kind Regards,
Cory
