Continue
  • My Subscriptions
  • Events
ITO 7.5.6 download
EcoStruxure IT Forum
  • Exact phrase โ†’ Use quotes " " (e.g., "error 404")
  • Wildcard โ†’ Use * for partial words (e.g., build*, *tion)
  • AND / OR โ†’ Combine keywords (e.g., login AND error, login OR signโ€‘in)
  • Keep it short โ†’ Use 2โ€“3 relevant words , not full sentences
  • Filters โ†’ Narrow results by section (Knowledge Base, Users, Products)
Showing results forย
Did you mean:ย
  • Re: ITO 7.5.6 download
Cory_McDonald
Cory_McDonald Champion
160
Jef
Jef Leader
114
gsterling
gsterling Mentor
77
Back to EcoStruxure IT Forum
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: โ€Ž2020-07-05 01:15 PM . Last Modified: โ€Ž2024-04-04 12:36 AM
4150
ITO 7.5.6 download
http://sxwhelpcenter.ecostruxureit.com/display/public/UADCO8x/What%27s+new+in+IT+Optimize
It says 7.5.6 is New but in the download links I only see 7.5.2...
Please advise,
J
(CID:134687515)
  • Data Center Operation
  • bug
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: โ€Ž2020-07-05 01:16 PM . Last Modified: โ€Ž2024-04-04 12:36 AM
4149
Yes, please note this comment I had posted above if you want to install ITO 7.5.2 on windows 2016.
use a windows command terminal to launch the ITO installer and specify the "--check_os_supported no" command line option (note there are two dashes in front of the argument).
GregS
(CID:134687761)
Replies 20
DCIM_Support
DCIM_Support Mentor
Mentor
May be a mistake with the download links. We'll check into this.
Greg Sterling
(CID:134687526)
DCIM_Support
DCIM_Support Mentor
Mentor
Thanks Greg. installing 7.5.2 on Windows Server 2016 doesn't work... Heard 7.5.6 would work per the installation guide.
(CID:134687536)
DCIM_Support
DCIM_Support Mentor
Mentor
Correct.
On the short term you should be able to install ITO 7.5.2 on windows 2016 if you use a windows command terminal to launch the ITO installer and specify the "--check_os_supported no" command line option (note there are two dashes in front of the argument).
Greg Sterling
(CID:134687538)
DCIM_Support
DCIM_Support Mentor
Mentor
Dear John Smith,
From your comments:
I'm surprised: for the third year I have been successfully using ITO 7.5.2 under MS Windows Server 2016 Core. I did not notice any problems during installation or configuration.
Why doesn't it work for you? What were your difficulties or mistakes?
With respect.
(CID:134687596)
DCIM_Support
DCIM_Support Mentor
Mentor
spezialist,
I got an error when running 7.5.2 it got a pop-up which says "The Schneider Electric IT Optimize installer is not supported on this operating system. Please consult the product documentation for supported operating systems."
I am trying to install this on Windows Server 2016 Standard with no luck!
J
(CID:134687615)
DCIM_Support
DCIM_Support Mentor
Mentor
4150
GregS
(CID:134687761)
DCIM_Support
DCIM_Support Mentor
Mentor
In response to DCIM_Support
We will correct the links on the download page.
Greg Sterling
(CID:134687765)
DCIM_Support
DCIM_Support Mentor
Mentor
Hello Greg,
Is the link for ITO version 7.5.6 available to download it?
Luis Lopez
(CID:136152721)
DCIM_Support
DCIM_Support Mentor
Mentor
My apologies Luis. I will get back to you.
GregS
(CID:136153182)
DCIM_Support
DCIM_Support Mentor
Mentor
Updating this posting. The download links on the download page have been updated to include ITO 7.5.6.
Greg Sterling
(CID:137730315)
DCIM_Support
DCIM_Support Mentor
Mentor
4149
Greg,
The command doesn't work. Or maybe it does. I get this alert now:
Problem running post-install step. Installation may not complete correctly. Error running C:\Program Files\SchneiderElectric\ITOptimize\java\bin\keytool.exe -genkeypair - alias dcos -keyalg RSA -keystore C:\Program Files\SchneiderElectric\ITOptimize\conf\keystore\dcos.keystore
... it goes on.
Any ideas? Or when the new file is posted, I can just download the one compatible with Server 2016.
(CID:136153311)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: โ€Ž2020-07-05 01:16 PM . Last Modified: โ€Ž2024-04-04 12:35 AM
Which version of ITO did you try to install? Was this 7.5.2?
Did you try installing with all of the default options or did you try to customize the installation directory?
Greg Sterling
(CID:136153314)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: โ€Ž2020-07-05 01:17 PM . Last Modified: โ€Ž2024-04-04 12:35 AM
It was 7.5.2 and it was all defaults. with local admin.
(CID:136153317)
DCIM_Support
DCIM_Support Mentor
Mentor
7.5.2 is not officially supported on 2016 although I wouldn't have expected you'd see that message.
I will email you directly if that's ok with next steps.
Greg Sterling
(CID:136153325)
DCIM_Support
DCIM_Support Mentor
Mentor
Greg Sterling
(CID:137730316)
DCIM_Support
DCIM_Support Mentor
Mentor
Dear Greg Sterling,
David Colocho is right: it is impossible to extract file StruxureWareItOptimize-setup.windows.x64.exe from archive StruxureWareItOptimizeWithServerAccess-setup-7.5.6.windows.x64.zip (MD5: A8859AA7B7AB82A33CC8A0340D73F7C0).
Please check and correct this annoying error.
With respect.
(CID:138810824)
DCIM_Support
DCIM_Support Mentor
Mentor
Thanks for posting. I will check and send an update.
Greg Sterling
(CID:138810863)
DCIM_Support
DCIM_Support Mentor
Mentor
I added to the comment which was also posted online. I was able to download the zip file from the download site, extract the contents with the built-in windows extract tool as well as 7-zip and I was able to install the contents.
The ITO zip which was posted earlier in January was corrupted and replaced a few weeks ago. Can you retry the download?
Greg Sterling
(CID:138811056)
DCIM_Support
DCIM_Support Mentor
Mentor
Dear Greg Sterling,
Indeed, now the zip-archive is already normally unpacked.
Thanks for support ๐Ÿ˜€.
(CID:138811112)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: โ€Ž2020-07-05 01:17 PM . Last Modified: โ€Ž2023-10-22 02:41 AM
Youโ€™ve reached the end of your document
WHATโ€™S NEXT?
Terms & Conditions Privacy Notice Change your Cookie Settings ยฉ 2026 Schneider Electric
