Continue
  • My Subscriptions
  • Events
ITA 9.6 authentication error
  • ITA 9.6 authentication error
Cory_McDonald Champion
160
Jef Leader
114
gsterling Mentor
79
Geevarghese
Geevarghese
Explorer
Posted: ‎2026-04-17 06:11 AM
430
installed ITA version 9.6 and restored backup from version 9.5.3 users cannot login using authentication sever and external system connectivity is also failing . ITA server 9.6 is on the same VLAN as version 9.5.3
Please assist with troubleshooting steps
  • DCIM Support
  • IT Advisor
gsterling Mentor
Mentor
Posted: ‎2026-04-20 10:23 AM
Hello. Are you able to login to your IT Advisor 9.6 server using a local (non authentication server user account)?
If yes, please login as a non AD/LDAP user account which has administrator level permissions, change to the configuration menu, then the Authenication Servers pane. Your authentication server may need to be trusted on the new ITA server.
From the authentication servers pane, click the edit button on your authentication server entry,  a popup window should appear containing your authentication server settings. Try scrolling down to the bottom of that pop-up window and click OK (no need to change any settings in the pop-up window).
If the authentication server is trusted the pop-up window will just close, but if it isn't trusted when you clicked OK, you may need to scroll back up in the pop-up window and accept the trust pane which may have appeared. If you had to complete this step this was the probably cause of your login issue.
Trust the authentication server and logout.
Now retry your user logins using AD/LDAP.
Regards
Greg Sterling
