Posted: 2020-07-04 10:15 PM . Last Modified: 2024-04-04 03:24 AM
(CID:134022907)
Posted: 2020-07-04 10:15 PM . Last Modified: 2024-04-04 03:23 AM
Dear Shoaib Maqsood,
If you mean reset NetBotz-4.x appliance to the default login values, then according NetBotz Rack Monitor 450/550/570 Installation and Quick Configuration Manual you need:
I hope this is what you need.
With respect.
(CID:134022919)
Hello dear,
I want to factory default the Rack monitor . Because i can,t access the rack monitor through network or console port .
(CID:134022947)
Posted: 2020-07-04 10:16 PM . Last Modified: 2024-04-04 03:23 AM
Then the above instruction is what you need.
However, you still need to serial connect your laptop/PC to the console port NetBotz-4.x appliance in accordance with the instructions:
With respect.
(CID:134022955)
what did you mean by ( step 1 ) .
(Connect USB A to USB mini B cable to the console port on Netbotz Appliance)
(CID:134023016)
This is 5-m (16.4-ft) USB cable included with your NetBotz-4.x appliance.
(CID:134023031)
Hello Dear,
I have a rack monitor 570. After applying this procedure it stop on a starting boot services. On other side when we connect this rack monitor with advance view utility it stop on this step. Image is attached for your kind reference.
(CID:136152978)
Hello Shoaib, please check this link: http://www.apc.com/nl/en/faqs/index?page=content&id=FA158175
(CID:134023009)
Dear Shoaib,
If the Netbotz is still reachable via a web browser, you can do the same by accessing the page below
http://Once the appropriate credentials are provided, it will bring up a message saying that the restart has been initiated.
Otherwise, you can do issue the configreset command after establishing a terminal emulation (HyperTerminal) session to the Netbotz appliance after following the instructions laid out in one of Spezialist's comments.
I hope this helps.
Kind regards,
Justine
(CID:134023213)
Tell us, please, have you solved this question or not?
With respect.
(CID:134026450)
Posted: 2020-07-04 10:16 PM . Last Modified: 2023-10-22 02:34 AM
