Continue
  • My Subscriptions
  • Events
How to clear DCE client login IP's/hostname from drop down list
EcoStruxure IT Forum
  • Re: How to clear DCE client login IP's/hostname from drop down list
Cory_McDonald
Cory_McDonald Champion
160
Jef
Jef Leader
114
gsterling
gsterling Mentor
77
Back to EcoStruxure IT Forum
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 06:28 PM . Last Modified: ‎2024-04-03 02:59 AM
1054
I recently changed DNS names and would like to clear the "Hostname/IP Address" values from the drop down list from DCE desktop client login screen.
(CID:141267744)
  • Data Center Expert
DCIM_Support
DCIM_Support Mentor
Mentor
Hi Ryan,
There's a folder under your user account on your system that looks something like this:
C:\Users\\.isxc\7.6.0\.metadata\.plugins\org.eclipse.core.runtime\.settings
If you delete that .metadata folder, the local client info is deleted and set back to defaults. If you delete the file "org.eclipse.ui.prefs" in the .settings folder, I believe you'll remove the IP info.
(CID:141267758)
Replies 2
DCIM_Support
DCIM_Support Mentor
Mentor
Hi Ryan,
(CID:141267758)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 06:28 PM . Last Modified: ‎2023-10-22 02:27 AM
