How to adjust decimal places for Temperature Sensors
EcoStruxure IT Forum
  • How to adjust decimal places for Temperature Sensors
Cory_McDonald
Cory_McDonald Champion
160
Jef
Jef Leader
114
gsterling
gsterling Mentor
77
Back to EcoStruxure IT Forum
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 04:49 PM . Last Modified: ‎2024-04-03 04:21 AM
2118
We are using DCE to monitor sensors from An AIMS device. While the DDF works the decimal place is in the wrong place. How can I correct this?>
(CID:139692000)
  • Data Center Expert
  • bug
Replies 10
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 04:50 PM . Last Modified: ‎2024-04-03 04:21 AM
2118
Dear Andrew Stoakes,
I suspect, that this is just an bug in your 3rd party device’s DDF-file. Therefore, it will be very correct if you find your device on a special DDF resource and perform Request modification there.
If you send your DDF-file to my private e-mail, I can also help you.
With respect.
(CID:139692054)
DCIM_Support
DCIM_Support Mentor
Mentor
In response to DCIM_Support
Thank for the reply., I Tried to request modification but the link to the page is broken "404 page not found". enviromux_16d.xml
If you could have a look and see if the decimal place issue is easy to correct that would be fantastic. DDF is attached
Appreciate the assistance
(CID:139692535)
DCIM_Support
DCIM_Support Mentor
Mentor
From your comments:
Can you send me the above specified DDF-file enviromux_16d.xml to a private e-mail address? Since when I try to load the above specified DDF-file, I get a "404 page not found" error ☹️.
Dear Panagiotis Karampis, can you help solve the problem with "404 page not found" error when you try to download the above specified DDF-file ( enviromux_16d.xml )? The same error is displayed if I click on the Request modification link on the https://ddf.ecostruxureit.com/view/ENVIROMUX-16D/NTI&queryString=enviromux device support page.
With respect.
(CID:139692642)
DCIM_Support
DCIM_Support Mentor
Mentor
The ddf request is working now.
Although I fixed the download issue, it is not perfect. I'll have to investigate further.
(CID:139692694)
DCIM_Support
DCIM_Support Mentor
Mentor
In any case, thank you for your support.
(CID:139693108)
DCIM_Support
DCIM_Support Mentor
Mentor
@Panagiotis Karampis, thanks for fixing the link but i am still unable to request a modification. all i get is the error "Something went wrong, contact us"
(CID:139693875)
DCIM_Support
DCIM_Support Mentor
Mentor
Andrew Stoakes, apologies for that. It should work now correctly
(CID:139693987)
DCIM_Support
DCIM_Support Mentor
Mentor
Unfortunately, I didn’t wait for you to answer my previous questions.
Therefore, I am sending you the fixed SNMP DDF-file enviromux_16d.xml  v.2, which is intended for STULZ-TI’s Advanced Integrated Monitoring System (STULZ-16DDP).
Try it, please, and carefully check whether everything is normal and correct.
With respect.
(CID:140215971)
DCIM_Support
DCIM_Support Mentor
Mentor
Ok, if there are any inaccuracies/errors/bugs or questions, please let me know.
With respect.
(CID:140216328)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 04:51 PM . Last Modified: ‎2023-10-22 02:25 AM
