Continue
  • My Subscriptions
  • Events
Hikvision Access control and CCTV integration with DCE
EcoStruxure IT Forum
  • Re: Hikvision Access control and CCTV integration with DCE
Cory_McDonald
Cory_McDonald Champion
160
Jef
Jef Leader
114
gsterling
gsterling Mentor
79
Back to EcoStruxure IT Forum
shoaibmaqsood52
shoaibmaqsood52
Contributor
Posted: ‎2023-12-31 09:19 PM
1716
We have installed the DCE AP9475 at one of our client site. Now our client requires integration of the Access control and CCTV with DCE.
Here we are using the Hikvision brand for CCTV and ACS. Please share the procedure if it is possible.
Need your swift response.
  • Data Center Expert
Justine
Justine Contributor
Contributor
Posted: ‎2024-01-01 11:25 PM
1697
Hi, StruxureWare DCE is only compatible with Netbotz appliances AFAIK. Only the cameras pods that can be added to the appliance can be used for Surveillance.
I think a similar question as raised a few years back:
https://community.se.com/t5/EcoStruxure-IT-forum/Hikvision-NVR-support-on-DCE/td-p/212619
Replies 3
Justine
Justine Contributor
Contributor
1697
shoaibmaqsood52
shoaibmaqsood52
Contributor
Posted: ‎2024-01-02 04:43 AM
In response to Justine
1689
Hi justine,
Kindly advise if Hikvision Access control is compatible with DCE or not?
Justine
Justine Contributor
Contributor
Posted: ‎2024-01-08 09:19 PM
In response to shoaibmaqsood52
Hi, No. As far as I know, access control is also limited to Netbotz appliances only.
