Generator start from DCE
EcoStruxure IT Forum
  • Re: Generator start from DCE
Cory_McDonald
Cory_McDonald Champion
159
Jef
Jef Leader
114
gsterling
gsterling Mentor
77
Back to EcoStruxure IT Forum
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 02:05 PM . Last Modified: ‎2024-04-04 12:17 AM
1338
Is there possibility to install a start button for a generator into a DCE?
It should be something like door handle command on Netbotz 250 & I am acctualy thinking of conecting generator instead of the door handle 😀
(CID:135433378)
  • Data Center Expert
DCIM_Support
DCIM_Support Mentor
Mentor
1339
Hello Boris,
Sorry, that is not currently possible.  The only things that Data Center Expert can control are NetBotz Rack Access and APC Switched Rack PDU Outlets.
Kind Regards,
Cory
(CID:135433423)
Replies 6
DCIM_Support
DCIM_Support Mentor
Mentor
1340
Hello Boris,
Kind Regards,
Cory
(CID:135433423)
DCIM_Support
DCIM_Support Mentor
Mentor
In response to DCIM_Support
Hi Cory,
Is it possible to control dry contacts on Netbotz??? I can use them to send command to a generator.
(CID:135433450)
DCIM_Support
DCIM_Support Mentor
Mentor
Maybe to send this as feature request.
(CID:135433451)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 02:06 PM . Last Modified: ‎2024-04-04 12:17 AM
You can submit feature requests under: Resources Menu > Feature Requests.
The NetBotz 250 has a relay that you can control via it's web interface.  Note that this will not be able to be done through Data Center Expert.  It must be done via the web interface of the NetBotz 250.
I am not aware if it has been tested or not, but the following design may also affect the NetBotz 250:
http://www.apc.com/us/en/faqs/FA158337/
Kind Regards,
Cory
(CID:135433477)
DCIM_Support
DCIM_Support Mentor
Mentor
OK, thanks for the info.
(CID:135433483)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 02:06 PM . Last Modified: ‎2023-10-22 02:07 AM
