Continue
  • My Subscriptions
  • Events
Fail to upgrade from DCE 7.2.7 to 7.3.1
EcoStruxure IT Forum
  • Re: Fail to upgrade from DCE 7.2.7 to 7.3.1
Cory_McDonald
Cory_McDonald Champion
160
Jef
Jef Leader
114
gsterling
gsterling Mentor
77
Back to EcoStruxure IT Forum
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 09:18 PM . Last Modified: ‎2024-04-04 03:49 AM
2114
So trying to upgrade a VM DCE.  Initially it had the standard HDD which did not have enough spare space to allow upload of the update file.  An additional HDD was added to avoid this issue.
The first attempt to upload resulted in hang of the DCE client and no change in the operation of DCE.
Second attempt allowed ht upload of the file and seemed start the update process but then bombed out to "Cannot retrieve data from DCE") about 13 seconds into "installing update stage 1".  The only way to get the server back up is to shut it down and restart it from the VM client
The DCE upgrade file was downloaded again and MD5 checked , but each attempt to update had the same result.
The server was configured with 1GB RAM and  1x CPU, The RAM was increased to 4GB to see if that helped but no change.
The log files show at the end of each attempt...
Restarting software to launch product upgrade Restarting ISXC software RMS Device API Engine shutting down 1 unposted events RMS Device API shutdown complete Received shutdown complete notify shutdown() returning SOCKS Proxy is already stopped! Batch Dispatcher - 3 has been interrupted and will terminate. Batch Dispatcher - 4 is no longer accepting events. Newly pushed events will be dropped. Batch Dispatcher - 5 has been interrupted and will terminate. Batch Dispatcher - 6 is no longer accepting events. Newly pushed events will be dropped.
As far as I can see it is not
  • Corrupt update files
  • Lack of disk space
  • Lack of RAM
I guess it could be lack of CPU but there seems to be no indication of this and the 3 items above are the only things that have stopped me doing updates in the past.
There are a lot of post error which appear to be from netbotz devices with expired certificates, I don't think this would cause the update to fail
Any assistance in what else it could be stopping the update please?
(CID:133368099)
  • Data Center Expert
Replies 13
DCIM_Support
DCIM_Support Mentor
Mentor
Dear Garry Priestland,
Have you tried making a full backup of the DCE-server and deploying it to a cleanly installed DCE-7.2.7? And then upgrade to DCE-7.3.1.
With respect.
(CID:133368437)
DCIM_Support
DCIM_Support Mentor
Mentor
Thanks - that was my next move, but wanted to avoid that effort if I could.
Also, although that may well cure the problem and allow an upgrade I would like to know what has caused the problem.
(CID:133368443)
DCIM_Support
DCIM_Support Mentor
Mentor
From your question:
...Initially it had the standard HDD which did not have enough spare space to allow upload of the update file.  An additional HDD was added to avoid this issue.
After this step please, check the free space on your DCE server's hard drive: http://DCE_address/nbc/compress/repository/status . How much free space?
With respect.
(CID:133368449)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 09:19 PM . Last Modified: ‎2024-04-04 03:49 AM
I can't get onto the server right now - it is not mine and it is remote.  The DCE client was showing about 50.2GB of free disk space
(CID:133368481)
DCIM_Support
DCIM_Support Mentor
Mentor
I would be grateful if you show the screenshot.
With respect.
(CID:133368491)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 09:19 PM . Last Modified: ‎2024-04-04 03:48 AM
2114
Unfortunately I did not take a screenshot - next chance to get on the server is in a few weeks time...
Was there something in particular you were thinking the issue could be?
(CID:133368495)
DCIM_Support
DCIM_Support Mentor
Mentor
In response to DCIM_Support
It's best to check everything. Try and report the result, please.
With respect.
(CID:133368498)
DCIM_Support
DCIM_Support Mentor
Mentor
Hi Garry,
Is there any chance we can get the latest capturelogs from the server?
This should give us more information about why the upgrade is failing.
Thanks & Regards
(CID:133368507)
DCIM_Support
DCIM_Support Mentor
Mentor
I do have the capturelogs - where can I upload them?  Prefer not to do it on a public forum.
(CID:133368512)
DCIM_Support
DCIM_Support Mentor
Mentor
Hi Garry,
I have sent you a link to a Box folder. Can you upload the capturelogs onto that, and I will have a look at them soon.
Thanks & Regards
(CID:133368818)
DCIM_Support
DCIM_Support Mentor
Mentor
Thanks John. Out of the office at the moment but will upload them soon...
(CID:133369242)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 09:20 PM . Last Modified: ‎2024-04-04 03:48 AM
Hi - the file has now been uploaded
(CID:133369883)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 09:20 PM . Last Modified: ‎2023-10-22 02:05 AM
