Continue
  • My Subscriptions
  • Events
Exporting specific DC
  • Exporting specific DC
Cory_McDonald Champion
160
Jef Leader
114
gsterling Mentor
77
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 07:45 PM . Last Modified: ‎2024-04-04 11:07 PM
2122
Hello everyone!
Im here looking for your help once again!
My inventory has for example 5 different rooms.
i want to take the 4th one and export it to HD and import on another server i own that has different license.
And i dont want any of the other DCs data to be exported, only the 4th one
Is there a way of doing this?
Thank you
(CID:132660032)
  • Data Center Operation
DCIM_Support Mentor
Mentor
2122
Hi Gleb,
You can use the Migration feature in DCO, it is available in desktop client, System Setup > Migrate from StruxureWare Operation
The migration feature can/may be applied between two different setups/installations and executable only once! (eg. multiple migration is not allowed).
1- take a backup of the current setup (5 rooms)
2- restore the backup on a test server
3- on the test server, delete the unwanted rooms
4- now the test server should contain the wanted room. Take a backup.
5- backup from step 4 can now be migrated to the destination server.
Note: it is recommended to take a fresh backup (on the destination server) before starting the migration.
Kind regards
(CID:132660138)
Replies 8
DCIM_Support Mentor
Mentor
2122
Hi Gleb
Not sure if there's a way to do exactly what you want.  perhaps you could backup/restore the entire DCO then delete the unwanted 4 rooms?
Way can't you take all 5 rooms?
Cheers
Ed
(CID:132660090)
DCIM_Support Mentor
Mentor
Um i will look into the deleting from backup way...
I need to take it to other site that dont need to have the others
(CID:132660140)
DCIM_Support Mentor
Mentor
2123
Hi Gleb,
Kind regards
(CID:132660138)
DCIM_Support Mentor
Mentor
Its a nice solution but my issue is that the two servers are not connected... I want to export the data to a HD and transfer it that way to the other server.
Is this achievable?
(CID:132660151)
DCIM_Support Mentor
Mentor
Hi Gleb,
Servers do not need to be connected.
The backup file (ex. from step 4) can be transferred/copied to a usb drive/disk/etc and then brought to any location you wish.
Kind regards
(CID:132660160)
DCIM_Support Mentor
Mentor
Thank you very much!!
Helped me alot!
Cheers
(CID:132660463)
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 07:46 PM . Last Modified: ‎2024-04-04 11:07 PM
Hi Gleb,
You are most welcome,
Kind regards
(CID:132660503)
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 07:46 PM . Last Modified: ‎2023-10-22 02:04 AM
