Device sensor details extract in DCE v7.4.3
EcoStruxure IT Forum
  • Re: Device sensor details extract in DCE v7.4.3
Cory_McDonald
Cory_McDonald Champion
160
Jef
Jef Leader
114
gsterling
gsterling Mentor
77
Back to EcoStruxure IT Forum
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 12:27 AM . Last Modified: ‎2024-04-04 12:54 AM
2020
Is it possible to extract serial numbers of Power Modules of Symmetra Px250/500 via DCE?
We have over 50 UPS's so is there an easy method to do so?
Chaitanya
(CID:134679418)
  • Data Center Expert
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 12:27 AM . Last Modified: ‎2024-04-04 12:53 AM
2020
Hi Chaitanya
I dont have a system in front of me but I recall the info you seek is available by SNMP/Web/command line but the DCE DDF does not display it.  Perhaps you can call out for an updated DDF?  in the meantime, if you or anyone has a little scripting skill, it's quite easy to craft a repeating process to pull the info from each of your UPSs.
I dont have access to a UPS and, for me, the units at testdrive,apc.com are greyed out.
I hope that helps, at least a little
(CID:134679450)
Replies 10
DCIM_Support
DCIM_Support Mentor
Mentor
2021
Hi Chaitanya
(CID:134679450)
DCIM_Support
DCIM_Support Mentor
Mentor
In response to DCIM_Support
Hi folks,
I'd imagine it would be something that would have to be added to the DDF as Ed noted. I checked the 250 I have SNMP access to and polled:
upsDiagnostics.upsDiagnosticPowerModules.upsDiagPMTable.upsDiagPMEntry.upsDiagPMSerialNum
.1.3.6.1.4.1.318.1.1.1.13.2.2.1.5
I only have a single module and the output was NA for all the instances except for the one that was installed.
There's nothing currently in DCE for this so potentially writing a batch file to run an SNMP command might be your best bet for right now if you simply want a list.:
Something like:
FOR /F %%x IN (iplist.txt) DO D:\usr\bin\snmpget -v 1 -c public %%x .1.3.6.1.4.1.318.1.1.1.13.2.2.1.5.1 >> %%x.txt
FOR /F %%x IN (iplist.txt) DO D:\usr\bin\snmpget -v 1 -c public %%x .1.3.6.1.4.1.318.1.1.1.13.2.2.1.5.2 >> %%x.txt
...all the way up to 318.1.1.1.13.2.2.1.5.10 for all power modules.
Adding lines for each instance and (assuming all the devices use the same community name...public in use here) the iplist.txt file would simply be a file with all the IPs of the devices listed:
192.168.1.10
192.168.1.11
and so on...
The output will be individual files each with it's name as the IP of the device polled. I created on a few years back for the single phase Symmetra where I pulled the (only 5) PM serial numbers, upsDiagPMManufactureDate,  upsDiagIMSerialNum, and upsDiagIMManufactureDate..
I downloaded the SNMP stuff from sourceforge.net. It's free but you can use any command line utility you want, just what I had available.
Clunky but it works.
(CID:134679715)
DCIM_Support
DCIM_Support Mentor
Mentor
Nice
(CID:134679835)
DCIM_Support
DCIM_Support Mentor
Mentor
Hi Ed and Steve,
Thanks for information provided.As I am new to Schneider electric I am learning things as I go.
I have logged to UPS via command line and there are no device commands to do that if that was available I would have written a script in teraterm to do that.
Serial info is available via UPS web interface but that really cumbersome.
Is it possible that I can get hold of documents for above commands so that I can build it myself.
I will let you know how this goes.
I have just downloaded the following text any supporting docs which will help me.
The APC PowerNet MIB can be downloaded here: http://www.apc.com/tools/download/index.cfm
Select Firmware Upgrades - MIB from the Filter By Software / Firmware drop down list and press Submit.
Again thanks for you help.
Chaitanya
(CID:134680132)
DCIM_Support
DCIM_Support Mentor
Mentor
Hi Chaitanya,
Yea, I wasn't sure what might be available using other methods and I knew SNMP had that info ... that's why I mentioned the batch file and provided the OIDs, If you use most command line SNMP utilities, the MIB is often not required.
(CID:134681069)
DCIM_Support
DCIM_Support Mentor
Mentor
Hi Steven,
Thanks for that I will write batch file, test it and let you know.
Chaitanya
(CID:134681476)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 12:28 AM . Last Modified: ‎2024-04-04 12:53 AM
Hi Steven,
Its all good works well.
Tweaked script to suit my needs
Thanks for you help.
Chaitanya
(CID:137107864)
DCIM_Support
DCIM_Support Mentor
Mentor
Dear Chaitanya ,
That is, do you want to export the serial numbers of power modules from a DCE-client to any spreadsheet, for example MS Excel?
Did I understand you correctly?
With respect.
(CID:134679519)
DCIM_Support
DCIM_Support Mentor
Mentor
Hi Spezialist,
That's correct!
I would like to export all the serial numbers of the UPS to excel spreadsheet.
Chaitanya
(CID:134680131)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 12:28 AM . Last Modified: ‎2023-10-22 01:53 AM
