Data from associated devices in DCO do not match with data on the devi
EcoStruxure IT Forum
  • Re: Data from associated devices in DCO do not match with data on the devi
Cory_McDonald
Cory_McDonald Champion
159
Jef
Jef Leader
114
gsterling
gsterling Mentor
77
Back to EcoStruxure IT Forum
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 03:12 PM . Last Modified: ‎2024-04-05 12:41 AM
1191
I have configured a DCE (7.5.0) as an External System Configuration to DCO (8.2.2), but the Data in DCO device window doesn't match with the data on the device:
Enzo
(CID:129406138)
  • Data Center Expert
  • Data Center Operation
Replies 5
DCIM_Support
DCIM_Support Mentor
Mentor
1191
Hi Enzo,
DCO will take peak power over the period based in settings for "calculate power data based on days' per picture below.
By default, it will keep last 30 days data.
The rack PDU NMC showed peak power of 10.11 kw back in 09/16/2015, which is more than 30 days.
For more information:
About Peak and Average Power Data Retrieval from StruxureWare Data Center Expert
(CID:129406335)
DCIM_Support
DCIM_Support Mentor
Mentor
In response to DCIM_Support
Hi Christopherus,
I was referring at the total KW, as you can see from the pic on the device is 7.78KW and in DCO is o KW
Enzo
(CID:129407095)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 03:13 PM . Last Modified: ‎2024-04-05 12:41 AM
Now that you mentioned,   the average power is shown as zero, and the average individual phase power has no data in DCO.
Jef Faridi, any idea?
I've highlighted Enzo's original screenshots on the average power:
(CID:129407141)
DCIM_Support
DCIM_Support Mentor
Mentor
I think I have found the solution, I applied the patch at:
http://sxwhelpcenter.ecostruxureit.com/display/public/UAOp74/Correcting+False+Power+Values+Reported+...
and now I am getting the right value
Enzo
(CID:129409434)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 03:13 PM . Last Modified: ‎2023-10-22 01:50 AM
