Continue
  • My Subscriptions
  • Events
DDF Files incorrect file type
EcoStruxure IT Forum
  • Re: DDF Files incorrect file type
Cory_McDonald
Cory_McDonald Champion
160
Jef
Jef Leader
114
gsterling
gsterling Mentor
77
Back to EcoStruxure IT Forum
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 02:10 PM . Last Modified: ‎2024-04-04 12:15 AM
1633
I have been trying to upload the DDF files for several devices that we have recently added. On several of the devices I get the error "Incorrect File Type".
The Stulz WIB8000 has this issues as shown in the attached screen shot.
(CID:136152805)
  • Data Center Expert
Replies 6
DCIM_Support
DCIM_Support Mentor
Mentor
1632
Dear Andrew Stoakes,
I suspect, that you are trying to import an SNMP DDF-file through the import menu for the Modbus DDF-file or vice versa.
Try importing the above specified DDF-file using the SNMP Device Communication Settings (not Modbus Device Communication Settings).
With respect.
(CID:136152898)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 02:11 PM . Last Modified: ‎2024-04-04 12:15 AM
In response to DCIM_Support
agreed, if you're unsure if your ddf is Modbus or snmp, you can open it with any xml viewer (this includes most web browsers) and look at the first few lines and you'll see either snmp oids or MODBUS_OID_MUST_EXIST
snmp
modbus
(CID:136153252)
DCIM_Support
DCIM_Support Mentor
Mentor
Please, tell us if you could solve this problem or not?
With respect.
(CID:137103281)
DCIM_Support
DCIM_Support Mentor
Mentor
1632
I have the same problem, I download LCP Rrital DDF file from APC but when I insert the xml downloaded file in DCE it shows incorrect file type, what can I do for fixing and using this df for connecting to Rital LCP and monitor it?
(CID:140218315)
DCIM_Support
DCIM_Support Mentor
Mentor
Dear afsaneh mobin,
I suspect, that you are trying to import an SNMP DDF-file through the import menu for the Modbus DDF-file.
Try importing the above specified rittal_lcp.xml v.1 DDF-file using the SNMP Device Communication Settings (not Modbus Device Communication Settings).
With respect.
(CID:140218359)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 02:11 PM . Last Modified: ‎2023-10-22 01:47 AM
