DDF Alarm configuration based on alarm text
EcoStruxure IT Forum
  • Exact phrase โ†’ Use quotes " " (e.g., "error 404")
  • Wildcard โ†’ Use * for partial words (e.g., build*, *tion)
  • AND / OR โ†’ Combine keywords (e.g., login AND error, login OR signโ€‘in)
  • Keep it short โ†’ Use 2โ€“3 relevant words , not full sentences
  • Filters โ†’ Narrow results by section (Knowledge Base, Users, Products)
Showing results forย
Did you mean:ย
  • Re: DDF Alarm configuration based on alarm text
Cory_McDonald
Cory_McDonald Champion
160
Jef
Jef Leader
114
gsterling
gsterling Mentor
77
Back to EcoStruxure IT Forum
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: โ€Ž2020-07-04 02:43 PM . Last Modified: โ€Ž2024-04-05 02:33 AM
2077
Hi.
I have created custom SNMP DDF for InteliLite NT AMF 25.
I have added some alarms (severity critical and notification) such as "Generator Running on Load"  or "Generator is Emergency Shutdown" .
But there are also 16 Alarm texts which appears when some alarm exists, for example:
Actual alarm:
Name/OID: alarmText.1; Value (OctetString): !*Wrn Low coolant
Non Actual Alarm:
Name/OID: alarmText.1; Value (OctetString): *Wrn Low coolant
NO Alarm:
Name/OID: alarmText.1; Value (Null): null
How can I add those 16 alarms in DDF, and how DCE should detect alarm presence based text not on a integer value (1 or 0)
Thanks in advance.
(CID:128763018)
  • Data Center Expert
  • DDF
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: โ€Ž2020-07-04 02:43 PM . Last Modified: โ€Ž2024-04-05 02:32 AM
Hi Ditte, Ara,
I've mentioned this post to the DDF team and I'm unsure exactly what they may want to do at this point. I never recommend creating your own DDF as I have seen issues where customer created DDF files have caused catastrophic failures in the system where it won't even boot fully. In such cases a restore and re-import of a backup prior to the addition of the DDF would be required.
The proper path for getting a DDF is to have the DDF team create it for you as described here:
http://sxwhelpcenter.ecostruxureit.com/devices
If the team is willing to assist, hopefully they can do something here but it may just require following the proper procedure to get a DDF created
Steve.
(CID:129404159)
Replies 5
DCIM_Support
DCIM_Support Mentor
Mentor
Hi Ara Orujyan, thanks for posting. Let's hope you find your answer here.
Kind regards Ditte
(CID:129403695)
DCIM_Support
DCIM_Support Mentor
Mentor
I hope, because this es really urgent for me and for us.
Unfortunately there is no any integers regarding this alarms only text.
(CID:129403862)
DCIM_Support
DCIM_Support Mentor
Mentor
Hi Ditte, Ara,
Steve.
(CID:129404159)
DCIM_Support
DCIM_Support Mentor
Mentor
Dear Ara Orujyan,
Your question is really not simple โ˜น๏ธ, as the above-mentioned genset control panel by ComAp vendor has unfortunately a simplified alarm system. This circumstance does not allow simply and unambiguously to read the state of the genset alarm sensors.
I also recently encountered this problem when I connected the Green Power Systems genset with InteliLite NT AMF 25 control panel via the Modbus TCP/IP gateway to the DCE-server.
Therefore, in order to successfully solve the above problem, we had to perform an analysis of the state of the required genset sensors directly in the DDF-file and make a decision about the presence or absence of the alarm (according to the vendors IL-NT AMF20/25 unit reference guide). This complicates the DDF-file, but this is a real practical solution. And for me it works great.
For example, my DDF-file processes more than 150 numeric and status sensors:
And, importantly, it has about 120 built-in Device Alarms, which really simplify the monitoring of the operation of an important generator:
With this set of Device Alarms, I no longer need to create custom Threshold Alarms in the DCE software. It's convenient, simple and understandable ๐Ÿ˜€.
Thus, the same approach to solving a problem can be applied to a similar DDF-file but according to the SNMP protocol, that you mention.
With respect.
(CID:132646795)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: โ€Ž2020-07-04 02:43 PM . Last Modified: โ€Ž2023-10-22 01:47 AM
Youโ€™ve reached the end of your document
WHATโ€™S NEXT?
Terms & Conditions Privacy Notice Change your Cookie Settings ยฉ 2026 Schneider Electric
