DCO Upgrade 8.2.12 to 8.3 failed
EcoStruxure IT Forum
  • Re: DCO Upgrade 8.2.12 to 8.3 failed
Cory_McDonald
Cory_McDonald Champion
159
Jef
Jef Leader
114
gsterling
gsterling Mentor
77
Back to EcoStruxure IT Forum
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 07:21 PM . Last Modified: ‎2024-04-03 02:41 AM
1689
Hi
The upgrade failed with many package errors
see upgrade log: 20190515 DCO Dev Upgrade 8.3 - Tentative 1.txt
Please note that I set the option "Do not download packages from the Internet"
Any ideas?
Best Regards
Yannick
(CID:143758351)
  • Data Center Operation
Replies 7
DCIM_Support
DCIM_Support Mentor
Mentor
1689
Hi Yannick,
Wondering if you had also checked the option that says "No thirdparty RPMs" ?
if the answer is yes, then please try only with checking the option "Do not download packages from the Internet".
Kind regards
(CID:143758363)
DCIM_Support
DCIM_Support Mentor
Mentor
In response to DCIM_Support
Hi Jef
No I had not
I also tried with this option in addition of "Do not download packages from the Internet".
The upgrade succeeded (see log in attachment) but I know this upgrade path is not recommended as nobody in our environment manage the thirdparty packages for the moment
20190515 DCO Dev Upgrade 8.3 - Tentative 3.txt
Kind Regards,
Yannick
(CID:143758500)
DCIM_Support
DCIM_Support Mentor
Mentor
Hi Yannick,
Many thanks for the update. Glad to hear the latest upgrade attempt was successful, thanks.
Kind regards
(CID:143758503)
DCIM_Support
DCIM_Support Mentor
Mentor
Successful sure but I am not fully satisfied as the thirdparty RPMs have not been updated
(CID:143758505)
DCIM_Support
DCIM_Support Mentor
Mentor
Hi Yannick,
If the upgrade process successfully upgrades to 8.3, then all should be good. The option for third party files usually may be relevant for custom installations on Redhat server.
By the way, it is important to not interrupt the upgrade processes (by leaving the upgrade page or manually restarting the server).
Kind regards
(CID:143758516)
DCIM_Support
DCIM_Support Mentor
Mentor
Had the same issue last night when upgrading to v8.3. I had to select both "Do not download packages from the Internet" and "No third party RPMs" for the upgrade to be successful.
Seams to be working fine.
(CID:143758774)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 07:21 PM . Last Modified: ‎2023-10-22 01:41 AM
