Posted: 2020-07-04 03:50 PM . Last Modified: 2024-04-05 12:27 AM
Jef Faridi Can we use Redhat OS on DCO server ?
Is it compatible with DCO ?
(CID:129412639)
Posted: 2020-07-04 03:50 PM . Last Modified: 2024-04-05 12:26 AM
Hi Waseem,
StruxureWare Data Center Operation 8.x can be installed on a Red Hat Enterprise Linux 7 server. For details and requiements please see the following page:
Installing DCO on Red Hat Enterprise Linux 7
Kind regards
(CID:129412646)
Hi Waseem,
Kind regards
(CID:129412646)
Jef Faridi I have a concern as you're aware we are using virtual environment (VM) for DCO but as per the VM team of our customer they only have redhat OS and we are bound to use that, previously we were using CentOS and i was aware for the installation procedures (Standalone offline) but here on Redhat it seems quite confusing
is it same in redhat also or we need to do the installation in different way
Pls suggest ?
(CID:129412756)
Hi Waseem,
The installation is not the same, it is different. When installing on Red Hat Enterprise, you install it (DCO) as a 'software' (without OS), so obviously you/customer have the full control over the OS and its security, updates, etc. The above mentioned page (Installing DCO on Red Hat Enterprise Linux 7) contains also the installation instructions.
Kind regards
(CID:129412848)
Posted: 2020-07-04 03:50 PM . Last Modified: 2023-10-22 01:40 AM
