DCO PostgreSQL Database Communications - Security & SSL
EcoStruxure IT Forum
  • 🔒 Closed
Cory_McDonald
Cory_McDonald Champion
160
Jef
Jef Leader
114
gsterling
gsterling Mentor
77
Back to EcoStruxure IT Forum
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 05:09 PM . Last Modified: ‎2024-04-05 12:01 AM
1882
DCO has PostgreSQL communication between the active and DR node on port 5432. Same port for opening DCO ETL Database for other servers to access which is unencrypted.
Can you advise how do we secure this?
Can we encrypt this via native database SSL in the DCO setup?
(CID:130682137)
  • Data Center Operation
  • security
Replies 4
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 05:09 PM . Last Modified: ‎2024-04-05 12:00 AM
1882
Hi Lai Yuan,
I have registered an enhancement case for this, so the possible improvements can be developed and added into a future DCO release. Thanks
Kind regards
Hi Lai Yuan (Lai Yuan Jiun)
Further investigation of this case: it turns out that the secure communication is supported already.
Database communication between "master" and DR node is secure (over SSL).
External access to ETL internal databases allow for both insecure access and secure access (over SSL) - both require username/password authentication. If you use psql command to access the internal ETL database you can e.g. use a connection string like:
    psql "sslmode=require host= dbname= user=" --password
The psql command will then prompt for the ETL user's password.
If you are using JDBC access with a driver compiled with SSL support, you can use the connection string:
    jdbc:postgresql://:5432/?sslmode=require
Connection would then be secure.
Kind regards
updated
(CID:131336552)
DCIM_Support
DCIM_Support Mentor
Mentor
In response to DCIM_Support
Thanks Jef, we have testing it and it works.
(CID:131966999)
DCIM_Support
DCIM_Support Mentor
Mentor
Hi Lai Yuan,
You are welcome & many thanks for the feedback.
Kind regards
(CID:131967037)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 05:09 PM . Last Modified: ‎2023-10-22 01:39 AM
