Continue
  • My Subscriptions
  • Events
DCO Adding Patch Panel or Patch Rack Above Cabinet
EcoStruxure IT Forum
  • Re: DCO Adding Patch Panel or Patch Rack Above Cabinet
Cory_McDonald
Cory_McDonald Champion
160
Jef
Jef Leader
114
gsterling
gsterling Mentor
77
Back to EcoStruxure IT Forum
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-03 02:20 PM . Last Modified: ‎2024-04-08 01:20 AM
1592
My customer's datacenter has 4U Patch Racks above each cabinet. I want to model this in DCO. Is it supported or what is the workaround? Is there any chance it will be available in the future versions? I attached the patch rack picture just to give you an idea. many data centers are using this solution nowadays.
Kind regards
(CID:114822130)
  • Data Center Operation
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-03 02:21 PM . Last Modified: ‎2024-04-08 01:20 AM
1592
Hi Kaan,
Modelling patch panels/patching enclosures above racks is unsupported - we have a similar feature request in our system and I will go ahead and add this to the existing case.
Currently the only supported option (or work around) I can think of, is to use rack mounted patch panels.
Kind regards
(CID:116362325)
Replies 6
DCIM_Support
DCIM_Support Mentor
Mentor
Hi Kaan Kutlug, thanks for posting. Lets see who can be of assistance here. @community any ideas?
Kind regards Ditte
(CID:115345154)
DCIM_Support
DCIM_Support Mentor
Mentor
1593
Hi Kaan,
Kind regards
(CID:116362325)
DCIM_Support
DCIM_Support Mentor
Mentor
In response to DCIM_Support
thanks.
(CID:116362722)
DCIM_Support
DCIM_Support Mentor
Mentor
I had the some problem. My workaround was to use higher U racks. For example there is a standard 42U APC rack and above that installed 4U "mini rack" then I represented in DCO with a 46U custom rack.
(CID:116363362)
DCIM_Support
DCIM_Support Mentor
Mentor
thanks for the information
(CID:116363403)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-03 02:21 PM . Last Modified: ‎2023-10-22 01:35 AM
