DCO 8.1, Placement Advisor - Watts per U Height?
EcoStruxure IT Forum
  • Re: DCO 8.1, Placement Advisor - Watts per U Height?
Cory_McDonald
Cory_McDonald Champion
159
Jef
Jef Leader
114
gsterling
gsterling Mentor
77
Back to EcoStruxure IT Forum
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-03 04:26 PM . Last Modified: ‎2024-04-08 12:38 AM
1353
I'm trying to use the asset provisioning tool in DCO 8.1 and for some reason almost every rack always has "Watts Per U Height" as yellow or red, never green, even in a completely empty rack, regardless of what equipment I choose.
can anyone explain this recommendation better and what it would it requires for it show green instead of yellow?  In my example above, I was using a 300 W server and 8.6 kw rack pdus
(CID:119050632)
  • Data Center Operation
DCIM_Support
DCIM_Support Mentor
Mentor
1353
My best guess is that Operations is warning you that if you continue to add 185W servers (as is the load shown in the screenshot) you will run out U-space before using all the capacity in the rack.
44 servers of 185W: 8.14 kW
Capacity of each rack PDU: 8.6 kW
Hope this helps.
Best,
Niels
(CID:119050828)
Replies 4
DCIM_Support
DCIM_Support Mentor
Mentor
1354
Hope this helps.
Best,
Niels
(CID:119050828)
DCIM_Support
DCIM_Support Mentor
Mentor
In response to DCIM_Support
Thank you both, Niels was right, changing it to a 500w 1U server made some green racks.  I assume there isn't way to disable/ignore specific placement advisor suggestions is there?
(CID:120129569)
DCIM_Support
DCIM_Support Mentor
Mentor
As Niels pointed out, "Watts Per U Height" is there to avoid stranded power capacity, if you try with a 1U server of 500W the "Watts Per U Height" should go green.
Or if you do not intend to use the full rack PDU capacity in a rack, you could set a design limit on the rack, which more matches the "power use" of servers you want to use.
BTW: "Watts Per U Height" never goes red, so the red racks are caused by something else.
Best,
Gert
(CID:119050977)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-03 04:26 PM . Last Modified: ‎2023-10-22 01:31 AM
