Continue
  • My Subscriptions
  • Events
DCIM 7.8.0 adding devices
  • DCIM 7.8.0 adding devices
Cory_McDonald Champion
160
Jef Leader
114
gsterling Mentor
79
mohamed.abohawash
mohamed.abohawash
Explorer
Posted: ‎2026-10-14 04:51 AM
186
I'm facing difficulties adding PDUs (8853) and UPSs (E3S - AD807 SNMP) and Uniflair (TDA0922A) to the Structureware DCE 7.8.0.
I can ping them but couldn't access them via web browser as well.
thanks in advance.
  • DCIM Support
APC_Steve Leader
Leader
Posted: ‎2026-10-15 04:31 AM
165
Hi @mohamed.abohawash ,
When you say you "couldn't access them via web browser", does that mean you can not launch them from DCE or you can't access them at all. I mean if you can't add them, I would not expect you to be able to launch through DCE.
Are devices on the public or private DCE LAN?
Is this some or all devices?
Have you configured the devices with a user name and password along with SNMP communications strings? They're not set by default any longer on APC devices.
This FAQ may help:
https://www.se.com/us/en/faqs/FA177081/
On another note DCE 7.8 is no longer supported. We're currently on 9.2.
https://community.se.com/t5/EcoStruxure-IT-Policies/End-of-Life-Policy/ta-p/446509
Steve
mohamed.abohawash
mohamed.abohawash
Explorer
Posted: ‎2026-10-19 06:59 AM
In response to APC_Steve
Hi Steve,
Thanks for the quick answer,
The problem is before reaching the DCE, probably I'll not have an issue adding them to the DCE, Ill explain below:
1- PDUs: I have 12 PDUs (AP8853), connected them to the private LAN of the DCE server, and I enabled the DHCP, they all got IP addresses normally within the range, I can ping them, but couldn't access them through the browser (to enable the SNMP etc), somebody mentioned that i need to upgrade the firmware, which is 6.8.2. please advise on how to do this and what cable i need.
2- E3S 20KVA: I have 2 pcs, same issue, i can ping them from my laptop but couldn't access them, i installed 2 versions of the SNMP Manager tool, also they couldn't discover them. the installed SNMP cards are one of my friend mentioned to replace the SNMP cards to the APC ones (the installed ones are SNMP DA807) i have the manual i tried the default IP address but nothing worked.
3- The Uniflair cooling are added and configured successfully.
(note I tried another laptop and another switch, but i still have the same issue).
Thanks in advance.
