Continue
  • My Subscriptions
  • Events
DCE postgresql-9.5 service Failed
EcoStruxure IT Forum
  • Re: DCE postgresql-9.5 service Failed
Cory_McDonald
Cory_McDonald Champion
160
Jef
Jef Leader
114
gsterling
gsterling Mentor
77
Back to EcoStruxure IT Forum
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 09:29 PM . Last Modified: ‎2024-04-03 12:48 AM
2724
The server went off-line over the weekend without any power interruption or any human intervention. The server lost communication with all devices and the client had to reboot it. When looking at the output through the console monitor the only thing that failed in the boot process was the postgresql-9.5 service. Is there a way to restart the database without losing the data or rebuilding from scratch?
(CID:147783953)
  • Data Center Expert
DCIM_Support
DCIM_Support Mentor
Mentor
2724
The only reason I've seen that error that is not corruption based is when you're using a VM and it's run out of HD space. Please make sure you have enough space and maybe add an extra drive to be sure. Do not increase the size of the existing drive(s)!
If it is corruption, you'll likely need to re-image or redeploy and bring in a backup.
(CID:147783977)
Replies 5
DCIM_Support
DCIM_Support Mentor
Mentor
2725
(CID:147783977)
DCIM_Support
DCIM_Support Mentor
Mentor
In response to DCIM_Support
Thank you Steve. The current size of the data looking the recent backup is only 361GB where the Server is an AP9475 Model with 5x300GB HDDs. Do you reckon this could be corruption? If so who can assist me with download link for the image?
(CID:147783987)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 09:29 PM . Last Modified: ‎2024-04-03 12:47 AM
If the size is that small then it is unlikely it's a space issue for a 1Tb raid. It's likely something's become corrupt. I've seen it a few times and have tried to work through it on a few occasions but have yet to find a resolution. The most expedient action is to restore and to obtain those files, you need to contact your local tech support directly. We can't provide the links on the forum.
(CID:147784002)
DCIM_Support
DCIM_Support Mentor
Mentor
Thank you.
(CID:147784034)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 09:29 PM . Last Modified: ‎2023-10-22 01:26 AM
