DCE: insufficient memory for the Java Runtime Environment to continue
Select a Country
  • DCE: insufficient memory for the Java Runtime Environment to continue
Cory_McDonald Champion
159
Jef Leader
114
gsterling Mentor
77
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 05:18 PM . Last Modified: ‎2024-04-04 11:58 PM
4728
I am getting this error in hs_err_pid680.log. Any thoughts?
# There is insufficient memory for the Java Runtime Environment to continue.
# Native memory allocation (nmap) failed to allocate 310378496 bytes for committing reserved memory.
 # Possible reasons:
 #   The system is out of physical RAM or swap space
 #   In 32 bit mode, the process size limit was hit
 # Possible solutions:
 #   Reduce memory load on the system #
    Increase physical memory or swap space
 #   Check if swap backing store is full
 #   Use 64 bit Java on a 64 bit OS
 #   Decrease Java heap size (-Xmx/-Xms)
 #   Decrease number of Java threads
 #   Decrease Java thread stack sizes (-Xss)
 #   Set larger code cache with -XX:ReservedCodeCacheSize=
 # This output file may be truncated or incomplete.
# Out of Memory Error (os_linux.cpp:2627), pid=680, tid=0x00007f126d07e700
 # JRE version: Java(TM) SE Runtime Environment (8.0_102-b14) (build 1.8.0_102-b14)
 # Java VM: Java HotSpot(TM) 64-Bit Server VM (25.102-b14 mixed mode Linux-amd64 compressed oops)
(CID:131336342)
Replies 5
DCIM_Support Mentor
Mentor
Dear John Smith,
Under what circumstances did the above problem occur?
Did this issue occur while the Linux desktop DCE-client was running?
With respect.
(CID:131336438)
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 05:19 PM . Last Modified: ‎2024-04-04 11:57 PM
That issue was found in the DCE Server logs. Not the client. I only have windows clients installed.
(CID:131336840)
DCIM_Support Mentor
Mentor
4728
Dear John Smith,
Unfortunately, it's not easy to tell the root cause of the above JVM error on the DCE-server ☹️. You can, of course, point out the lack of RAM, but this is only true if your DCE-server has only 1GB of RAM (i.e., Basic DCE appliance), and the number of monitoring devices reaches up to a thousand.
Therefore, if this problem is not frequent and regular and does not involve a real lack of RAM, then I recommend simply updating your DCE-server to the latest version 7.5.0. This is a good practice, because judging by your log-file, the JVM version is old (latest version is 1.8.0_171), and updating the DCE-server you get also the latest version of JVM, which is very important for the normal operation of DCE software.
With respect.
(CID:131337109)
DCIM_Support Mentor
Mentor
Thanks. The server has plenty of RAM, I think it is 16 or 20GB and 5 Cores. It should be flying!
(CID:131958416)
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 05:19 PM . Last Modified: ‎2023-10-22 01:25 AM
