DCE VM failing to start after adding disk
EcoStruxure IT Forum
  • DCE VM failing to start after adding disk
Cory_McDonald
Cory_McDonald Champion
159
Jef
Jef Leader
114
gsterling
gsterling Mentor
77
Back to EcoStruxure IT Forum
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 09:13 PM . Last Modified: ‎2024-04-03 12:54 AM
2162
Our DCE VM was continually running out of disk space so I followed the procedure to add an additional disk however now when the server boots it just continually says "Data Center Expert is starting up"
When the disk was added I saw the additional capacity being added on the console and it completed successfully.
It appears that there is an issue with the postgresql-9.5 service as it fails to start.
I've tried rebooting a number of times without any luck.
There is nothing on the console to show any other errors
Is there any way to repair this without having to redploy the server?
Paul
(CID:147200799)
  • Data Center Expert
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 09:13 PM . Last Modified: ‎2024-04-03 12:53 AM
2163
Dear Paul Armstrong,
Most often, the above postgresql-9.5 service error is caused due to lack of free space on the DCE storage.
 Now you have two ways to solve your problem:
  1. restore the DCE server from backup (I hope you do this regularly);
  2. or contact your local =SE= support service (you must have a valid support contract).
With respect.
(CID:147201131)
Replies 6
DCIM_Support
DCIM_Support Mentor
Mentor
2163
I hope you followed the Adding disk space to a virtual appliance instructions exactly:
To increase storage for the virtual appliance, you must create additional hard disks.
 You cannot change the size of an existing hard disk, or remove a hard disk once it has been created. An error will occur on the primary interface, and the StruxureWare Data Center Expert virtual appliance will not start.
See, for example, a similar post  on this topic.
With respect.
(CID:147200821)
DCIM_Support
DCIM_Support Mentor
Mentor
In response to DCIM_Support
I followed the procedure exactly. I saw LVM resize when it was powered back on everything appears ok apart from the postgresql service which isn't starting.
I've rebooted a number of times and it's same error each time. I logged in as apcinfo and everything looks fine on the screen.
(CID:147200833)
DCIM_Support
DCIM_Support Mentor
Mentor
2164
With respect.
(CID:147201131)
DCIM_Support
DCIM_Support Mentor
Mentor
Thanks for replying.
In this case the error occured after trying to add free space to the storage.
I re-deployed the OVA this morning and restored from backup and everything is now operational again (with the extra storage added as well).
Thanks again
Paul
(CID:147201134)
DCIM_Support
DCIM_Support Mentor
Mentor
Ok, very thanks for the good feedback 😀.
(CID:147201137)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 09:13 PM . Last Modified: ‎2023-10-22 01:21 AM
