Continue
  • My Subscriptions
  • Events
DCE - APC SNMP Device Configuration is not available
  • DCE - APC SNMP Device Configuration is not available
Cory_McDonald Champion
160
Jef Leader
114
gsterling Mentor
77
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 04:15 AM . Last Modified: ‎2024-04-05 03:03 AM
1663
Running on 7.4.1 Expert I found that APC SNMP Device Configuration option is not available.
As you can see It is an APC Smart UPS SRT 6000. It is not a firewall issue with device communcation because on the same VLAN I have two 7723 ATS which are allowing me to select APC SNMP Device Configuration.
(CID:128068266)
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 04:16 AM . Last Modified: ‎2024-04-05 03:03 AM
I think since this is DCE 7.4.1, you need to update your core.xml DDF file to fix this issue as it is part of the symptoms you can see with the older file and newer firmware on NMC enabled devices.
See here for a summary and the actual DDF file you need to update: http://www.apc.com/us/en/faqs/FA303882
Try loading the DDF up and rescanning/rechecking the devices after the system has the new DDF file. The file is pre-loaded and updated in newer DCE revs moving forward.
(CID:128068449)
Replies 5
DCIM_Support Mentor
Mentor
Hi Mate,
The only time I have ever seen menu items unavailable like that is if the user was not a server admin or at least an admin of the group he was looking at. Are the SRT and the 7723s in the same device group? If you go through the top menu and select APC SNMP Device Configuration, do you see all devices or is it limited to specific devices?
Steve
(CID:128068300)
DCIM_Support Mentor
Mentor
(CID:128068449)
DCIM_Support Mentor
Mentor
Thanks both tips.
@steven: I am server admin and ATS are in the same group with UPS and PDU. The strange thing is that I also cannot see the application versions of PDU and UPS.
How can I download the latest DCE version and can I ugrade directly from 7.4.1?
(CID:128747786)
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 04:16 AM . Last Modified: ‎2024-04-05 03:02 AM
Hi Mate,
The k-base Angela mentioned also notes that the version is part of the core.xml issue. I wasn't aware that this also caused the issue that you are seeing as well but if you'll notice, the k-base Angela mentioned has been updated.
As for updates to DCE version, you must contact your local tech support for these and they must validate valid support contracts.
Steve
(CID:128747788)
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 04:16 AM . Last Modified: ‎2023-10-22 01:13 AM
