DCE 9.2.0 upgrade issues
Send InviteCancel
Posted: 2026-10-0707:28 AM
We upgraded to DCE 9.2.0. Good things are it fixed out issues with backups not working. Also fixed our issue with not being able to launch to NMC3 devices.
Bad thing is we are no longer able to launch NMC2 devices. Worked great prior to the upgrade. The majority of our devices are NMC2. This includes PDUs, Inrow Cooling units and rack PDUs.
We have opened a case, just checking if others have seen similar issues.
Posted: 2026-10-0907:02 AM. Last Modified: 2026-10-0907:06 AM
can you pm me the case number or provide any specifics here? I tested device launch to a Netbot 250 running nmc2 firmware 7.1.8 on the public DCE side and it worked as expected. I also tested with a rack pdu running 7.1.4 on the private lan, and again worked as expected. Autologin worked as well in both instances and this was using "DCE" security policy.
If these are private lan devices, is DHCP enabled and are they within DCE's DHCP scope with DCE being the first ip (eg 192.168.1.1-16, dce being 1.1)
Posted: 2026-10-1908:54 AM
just replying that I upgraded one of our nmc2 rack pdus from 7.1.4 to the latest 7.2.6 and private side device launch/auto login still works as expected.
