Posted: 2026-04-15 08:34 AM
Following upgrades to EcoStruxure IT Data Center Expert 9.1.1, backups are consistently failing across all upgraded servers.
Kernel logs show repeated I/O stalls exactly when backups run:
Version 9.1.1 was intended to improve backup reliability, but in our environment it has made the situation worse.
Has anyone else seen this in 9.1.1?
Posted: 2026-04-16 09:36 AM
@efantino,
That error message is an rsync error message (used for backups) that displays when there is an I/O problem with slow network disks. I would recommend working through technical support for them to analyze further if needed to determine if the issue is a connection to the backup share or something else.
Kind Regards,
Cory
Posted: 2026-04-29 10:41 AM
We ran into the exact same issue after the upgrade. Opened a case weeks ago. Just heard from support this morning and needed to get them some more information. Support let us know that they have a large backlog, so it took longer to respond.
