Continue
  • My Subscriptions
  • Events
Connect Ecostruxure gateways to EcoStruxure IT account
EcoStruxure IT Forum
Showing results forΒ
Did you mean:Β
  • πŸ”’ Closed
Cory_McDonald
Cory_McDonald Champion
160
Jef
Jef Leader
114
gsterling
gsterling Mentor
79
Back to EcoStruxure IT Forum
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: β€Ž2020-07-04 11:35 PM . Last Modified: β€Ž2024-04-04 02:30 AM
3008
How connect/link/subscribe ecostruxure gateway to EcoStruxure IT account ?
I want to connect 2 EcoStruxure Gateways (installed on different servers) to 1 EcoStruxure IT account, so the information from the 2 locations can be seen together.
How is the link made/setup between EcoStruxureGateway and the EcoStruxure IT account ?
KR,
Patrick
(CID:134031710)
  • IT Expert
DCIM_Support
DCIM_Support Mentor
Mentor
3007
Dear Patrick Hesters,
In fact, everything is very simple πŸ˜€. I highly recommend the new resource EcoStruxure IT Training, which will help you quickly understand this new SE digital service.
In short, first you need to install EcoStruxure IT Gateway software on two of your different sites (you already know about it πŸ˜‰.
For normal operation it is important, that this gateway software has access to the Internet in accordance with the System requirements:
Firewall
  • Port 443 TCP outbound
  • To connect using static IPs, add 40.84.62.190 and 23.99.90.28
I.e., your both gateway servers must have outbound network access to SE cloud servers (40.84.62.190 and 23.99.90.28) on 443 TCP port (HTTPS).
Second, go to the EcoStruxure IT management portal https://app.ecostruxureit.com/manage/ and register on it.
Then go back to your two servers with the gateway software. If you did everything correctly, then on the initial web-page of the gateway software you will see the registration code for the SE digital service and a special web-link for registration. Click on this web-link, you will be taken to the above mentioned EcoStruxure IT management portal. Again login on this management portal and if everything is successful, you will be notified of the successful registration of your first server with the gateway software.
Then repeat the above steps for your second server with the gateway software. You can see and control both of your gateway servers as it is written in the instruction 8c. Managing GATEWAYS (settings).
I hope this will be useful to you.
With respect.
(CID:134031758)
Replies 8
DCIM_Support
DCIM_Support Mentor
Mentor
3007
Firewall
With respect.
(CID:134031758)
DCIM_Support
DCIM_Support Mentor
Mentor
In response to DCIM_Support
I have found following window in EcoStruxureIT to connect EcoStruxureGateway.
I just do not know where I can find the info needed to enter in the boxes.
Who knows it ?
(CID:134031894)
DCIM_Support
DCIM_Support Mentor
Mentor
Hi Spezialist,
I will have a look at the EcoStruxure IT Training.
When I understand well your answer :
Connection between "Gateway" and Ecostruxureit.com site has to initiated from the Gateway.
I have already an EcoStruxureIT account, and when I look under settings, I see here the possibility to connect a gateway . .  ?
Here you have to mention a "name"  and a "registration code"
Or are both ways equal / possible ?
KR,
Patrick
(CID:134031766)
DCIM_Support
DCIM_Support Mentor
Mentor
From your comments:
That's right. To be precise, your gateway initiates a connection to the main SE cloud host 40.84.62.190. If this main SE cloud host is unavailable, the connection is switched to the standby SE cloud host 23.99.90.28.
Name you are free to write any you like πŸ˜€, the main thing that you understand what this gateway is and where it is.
Registration Code you need to look on the initial web-page of your gateway server, that is, at https://localhost/gateway/ (for more details see What is new in EcoStruxure IT).
With respect.
(CID:134031776)
DCIM_Support
DCIM_Support Mentor
Mentor
For more information about the initial configuration of the gateway software, see web page https://ecostruxureit.com/download-and-set-up-ecostruxureit-gateway/.
With respect.
(CID:134031981)
DCIM_Support
DCIM_Support Mentor
Mentor
3007
Dear spezialist,
Thanks for your feedback.
It is clear to me now !
With  respect,
Patrick
(CID:134031993)
DCIM_Support
DCIM_Support Mentor
Mentor
Ok, thanks for the good feedback πŸ˜€.
(CID:134031999)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: β€Ž2020-07-04 11:36 PM . Last Modified: β€Ž2023-10-20 05:09 AM
Terms & Conditions Privacy Notice Change your Cookie Settings Β© 2026 Schneider Electric
