Configuring LDAP over SSL using port 636 Not working
Select a Country
  • Configuring LDAP over SSL using port 636 Not working
Cory_McDonald Champion
160
Jef Leader
114
gsterling Mentor
77
Ajil
Ajil
Explorer
Posted: ‎2026-06-22 01:48 AM
282
Dear Team,
We have verified that Active Directory / LDAP connectivity is working successfully from DCE when using LDAP port 389 without enabling the SSL option.
However, when configuring LDAP over SSL using port 636 and enabling the SSL checkbox, DCE is unable to connect to the AD/LDAP server.
Current status:
  • LDAP (Port 389): Working
  • LDAPS (Port 636): Connection unsuccessful from DCE
Please investigate and advise.
APC_Steve Leader
Leader
Posted: ‎2026-06-23 04:13 AM . Last Modified: ‎2026-06-23 04:28 AM
Hello @Ajil ,
You'll need to install the AD server's SSL cert into the server certificates page of Data Center Expert. There is some mention of that here:
https://www.se.com/us/en/faqs/FA158395/
If it works on the default port without SSL then this would be the most likely reason i twould fail. Either you didn't install the cert into DCE or there is an issue with that cert.
This is a command example that using your server name, should get all necessary certs to add to the DCE server certs config.
openssl s_client -showcerts -connect your.adserver.com:636 < /dev/null
Steve
