Continue
  • My Subscriptions
  • Events
Bus bar power distribution
EcoStruxure IT Forum
  • Bus bar power distribution
Cory_McDonald
Cory_McDonald Champion
160
Jef
Jef Leader
114
gsterling
gsterling Mentor
77
Back to EcoStruxure IT Forum
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 11:51 PM . Last Modified: ‎2024-04-02 11:47 PM
988
Hello again,
how can we add the bus bars in our power path?
(CID:152079511)
  • Data Center Operation
Replies 2
DCIM_Support
DCIM_Support Mentor
Mentor
Hi Mihalis, I'm for sure curious to see what the Schneider team would recommend as a standard here. We have Bus Bar distribution as well and have an active project to get BCM integration fully mapped to drive capacity metrics, etc.
It basically comes down to modeling a standard PDU and then creating panels which represent each bus bar feed. We've set the panels using the modular setting... with 255 positions since we are integrating with ModBus. As we snap in the tap boxes and model out the receptacles.. we try to match the labeling using  panel/position.
We have also adopted a standard where we use the DWG autocad back ground layers to visually mark up the floor map showing which bus bars go where. Trouble though, as you may know... the standard layers of DCO overlay on top of the CAD layer... so it's not ideal.
(CID:152569487)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-05 11:51 PM . Last Modified: ‎2023-10-20 05:03 AM
