Continue
  • My Subscriptions
  • Events
Branch circuit monitoring and sensor mapping in amps
  • Branch circuit monitoring and sensor mapping in amps
Cory_McDonald Champion
160
Jef Leader
114
gsterling Mentor
79
jzurera
jzurera
Troubleshooter
Posted: ‎2026-10-26 10:16 AM
214
Hi team,
we have integrated power meters from DCE in ITA that show the current of different breakers that feed rack pdus.
We see the peak current properly in the power pop-up window, but we do not see the power information in the 2D view in the rack bars. Is it mandatory to include in the sensor mapping the information regarding to the power? We have only configured the sensor mapping in current, because the data that we have is only amps.
Do we have to convert this amps to watts multiplying by 230v in the power sensor mapping tab?
Thanks in advance.
  • IT Advisor
gsterling Mentor
Mentor
Posted: ‎2026-10-27 04:54 AM
Hello.
Yes. the tool-tip bars are based on watts, not amps so you will need to sensor map the amps data in the power sensor mapping view and convert the amps to watts using the multiplier field.
You may need to check the specs on the device to see the correct volts for the individual circuits as while the power meter may accept 230V, the per phase voltage may be different.
Regards
Greg Sterling
gsterling Mentor
Mentor
Hello.
Regards
Greg Sterling
