Posted: 2020-07-04 11:14 PM . Last Modified: 2024-04-04 02:37 AM
Hi team,
is there any way to receive an alert when DCO's backup fails?
I only know the option to check the backup status in Webmin, but customer does not see this an easy way to check that it is working properly.
Regards
(CID:134029618)
Hi Javier,
How about letting DCO to be monitored by DCE. DCO supports SNMP status codes (including backup failed status), so the alarms can be notified on DCE server. For details & instruction please see the following page(s): DCO SNMP status codes
Enabling Data Center Operation monitoring through Data Center Expert
Kind regards
(CID:134029644)
Hi Javier,
Kind regards
(CID:134029644)
Thanks, that works pefect.
(CID:134030242)
You are most welcome & many thanks for the update.
Kind regards
(CID:134030285)
Posted: 2020-07-04 11:14 PM . Last Modified: 2023-10-20 05:02 AM
